Has wiring near a/c compresser got ripped out, or pin out of wiring plug
This car had accident and after that the air condition won’t work, it only give out hot air. All fuses are okay, accident at front right .
please does it need any special reset or reflashing of module to make it work, as some cars when they re involve in accident the a/c module need to be flash before the system can work, I want help to this car,
2018 Nissan kicks..
thanks for the support
forumoto (9th January, 2020)
Cleared all dtc then Compressor began to work, I gave it to the client. In 2 hours time, I had a call that the A/C stopped working. I ask that the car should be return. So am waiting to see what exactly would be the issue in there. There is U1000 and U1001 which it’s not in A/C module
but rather Ecm, Abs, IC. The distance sensor ( radar) in front of the car was damaged in the accident because of that the Modules are throwing the U codes and it has not been replaced, well I don’t know if that could cause the A/C to shut off or not but am waiting for the car morrow if God permit us, I will probe more to see what best to do, if possible help find different line which can keep the compressor running constantly
Is it possible there are damage wires on the sensor
