Results 1 to 9 of 9
    YCFYCF's Avatar
    Nov 2019
    SL
    Default peugeot 406 2002 RFN Alternator wiring
    hi
    please need help with a peugeot 406 2002 RFN engine alternator. its a brown connector with two pins. the wires are not there. i checked all the AC compressor wiring , engine oil sensor wire and power steering pressure sensor wires are there. i checked all the harness way to the ECU, nothing. please need help with this.
    thanks.
    Meat-Head's Avatar
    Odd, if they is nobody looking, get a 501 bulb, one wire of bulb to ignition switched off under bonnet fusebox,
    then poke and hope the other side to one of smaller pins on alternstor
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    YCFYCF (18th November, 2020)
    Jul 2013
    yorkshire
    Has it got the correct alternator fitted?
  5. The Following User Says Thank You to autoden For This Useful Post:
  6. #4
    YCFYCF's Avatar
    Nov 2019
    SL
    thanks for ur reply. yeah i checked with a bulb to the excitation pin, bulb goes off when engine starts. but i need wiring diagram to the system from the alternator. coz the MFD shows "battery charging fault" . and the battery indicator in the dash is lit.
    YCFYCF's Avatar
    Nov 2019
    SL
    Quote Originally Posted by autoden View Post
    thanks . yes its the correct one. how come the wiring to the alternator isnt there.
  8. #6
    Meat-Head's Avatar
    ON TOPIC:-
    vague mode on:-
    can yiu upload quakkty photo of under hood fusebox
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
  10. #7
    YCFYCF's Avatar
    Nov 2019
    SL
    Thx guys I got it fixed
    Sent from my SM-G610F using Tapatalk
  11. #8
    Meat-Head's Avatar
    Great no wonder you got lots of red starts
    WHAT THE FRIG WAS IT???
  12. #9
    YCFYCF's Avatar
    Nov 2019
    SL
    Lol. Tracked the lines from another car... one to the BSI. and other to the BSM.
