It will work fine in Windows 7 x32 bit too.
And yes,you can diagnose your berlingo with this version.
Spencer024 (9th January, 2020)
Hi folks .. looking for help again please?
I received my interface and disk...head is already melted...I stupidity left dist auto install when I inserted it and setup drive in virtual PC which is xp 32 bit through virtual box..after install all looked good it opened as v7.01 and once closed and restarted it had updated to v7.02.. it did activate ok..as well ..
Here's where my problem lies..when I tried to run the first update on the disk whick is v7.01 to v7.57 is just won't run as in show the progress bar installing the update..it just give me the quit option with 'ne pas' something or other in french which I presume is not allowed..
I'll see can I attach pic with phone...
The thing is I did a uninstall with s/w on disk... reinstalled and ended up in the same place.. I could not get the dtlite install to run from disk so I downloaded it...i mounted the iso but it didnt ask to install or open so I clicked setup on the disk and it installed...is it at this point I'm going wrong and it's not seeing the mounted iso file or I'm not starting the install from the correct place ..
bout 5 hours gone into it now and I'm stumped..
I'm usually not too bad at following guides as I did to create virtual pc form YouTube video ..
Thanks in advance for any pointers.
Tom.
I'm a ~~~~ing dope after some translation lessons..it reads not enough disk space
Another amount of googling to be done on increasing disk space on VM
Me back again at this mad hour of the morning...long story short...I've got up as far as Diagbox 7.57 on a virtual xp machine and it seem to be activating..it's very slow to open but gets there .
I'm doing this really as a hobbiest as I no fault a currently on van and after spending about 20 hours setting up 3 virtual machines before I think I got it right...I can only imagine how good and how much work "Scarymistake " put into get this stuff working..
Anyways..back on point...I have a Sept 15 Berlingo van and wondering if I should update any further and if v7.57 is enough to communicate with my van when I attempt to do so when I gat a chance..🙃🙃
Tom.
Wet dreams. This will never connect with the server for updates.
Coz its a free world , and you asked...
Fair play to you...shur it's one way of getting your number of posts up a bit anyway ��������
For reference propose...I've been able to connect to the van with v7.57 and run through the global test...just a potter around a few of the screens to get used to it...will surely come in handy for fault diagnosis down the line...
Stelaras26 (16th January, 2020)
