Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 43
Thread: Carprog v12.45
  1. #16
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by pena View Post
    Тhe version 12.45 is last version on original software. Work perfekt with clone carprog 8.21 online. Before i uploading this version, i tested it how it work, and what it works for.
    Nothing burns and nothing breaks down,no counter was triggered. Tested with a libs 150428CAR00542UA and 150428CAR00491KW. On my clone carprog i not update A1+ adapter, because i dont have, but other people have done it successfully.
    Does anyone have working firmware 8.21 online (AT91SAM7s256)?
  2. #17
    Feb 2013
    Bulgaria
    Quote Originally Posted by hivrich View Post
    This is arhive with libs and flash firmware (AT91SAM7s256) for Carprog 8.21 online, work perfekt. Arhive no password:
  3. The Following 39 Users Say Thank You to pena For This Useful Post:
    AGK (28th July, 2024), bolonc (3rd August, 2022), boxsport (21st January, 2020), brodaty (26th January, 2020), carradio2001 (13th May, 2020), Cesarec (18th October, 2022), clc79 (2nd September, 2020), Col19 (28th October, 2021), Darek90 (13th May, 2020), ecufix (11th February, 2020), elservis (22nd March, 2020), erdilmen (27th February, 2024), florin_leo (27th January, 2023), gaben8 (31st March, 2020), gobe (29th January, 2020), habbou (29th May, 2020), hivrich (21st January, 2020), hoangtu (27th October, 2020), IIpoqpeccop (29th June, 2021), irstar (21st March, 2021), jmgameiro (16th March, 2022), kafsha (3rd September, 2022), kaziukas1958 (23rd June, 2023), madbg (23rd March, 2020), maremuruk (4th May, 2022), MARIKO (24th November, 2021), martinracing (13th April, 2020), motocarlos (11th March, 2020), mr.marius (11th January, 2023), nik6601 (16th December, 2020), olegario (21st January, 2020), PhilipArt (9th March, 2020), SALAS (13th May, 2020), svallecilla (16th February, 2020), Talleresmalaga (13th May, 2020), tigar (13th May, 2020), Vagilektro1 (3rd August, 2022), volodin69 (27th February, 2022), xseva (8th February, 2020)
  4. #18
    Mar 2020
    how flash the firmware thanks..
  5. #19
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by corsair87 View Post
    If you search a little in here,you will find the way.
    If i Helped you,use thanks and rep button to thank me back
  6. The Following User Says Thank You to Stelaras26 For This Useful Post:
  7. #20
    Mar 2020
    Quote Originally Posted by Stelaras26 View Post
    i have the carprog the 8.21 online (clone) and i open the programm 12.45 and work ... need flash or not? Thanks
  8. #21
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Nope.Just install the software and put your lib inside teh folder.Should work.
  9. The Following 3 Users Say Thank You to Stelaras26 For This Useful Post:
    irstar (21st March, 2021), rtbdiagnostic (10th March, 2020), Talleresmalaga (13th May, 2020)
  10. #22
    carradio2001's Avatar
    Nov 2009
    France
    What difference between this two versions ?
    150428CAR00542UA
    150428CAR00491KW
    Regards,
    Carradio2001.
  11. The Following User Says Thank You to carradio2001 For This Useful Post:
    Transporter86 (27th February, 2021)
  12. #23
    Feb 2011
    EU
    Hi!
    What needs to be done for vespa r5f1 renesas to work?
    Thank you!
  13. #24
    Oct 2020
    Hello. I need to read data from HP5T 14B321 AF. Can I do this with Carprog v12.45?
  14. #25
    Dobermann's Avatar
    Germany
    Hello did someone know if this will work with original Carprog interface ?
    i have original carprog but not all funtions.
    what happen if i use this lib file and online software ?
    will this lock my original inteface ? maybe this lib file is on blacklist ? or will not work because my ori interface have other serelnumber ?
    did someone tested this ? or know this ?
    would be nice if somone can share his experiance.
    thank you !
    just for info the aktuell carprog soft is now 13.19
    MM Flex Full , KESS3, KESS V2 and KTAG Original , ECM Titanium Genuine, CarProg V14, MPPS V22
  15. #26
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    I start to say about subscrition mode , that s mean you can buy from codecard.lt to make your carprog 2021 update ,cost now 560 EUR for 1 year .
    I you don t want subsciption your toll remain to program the date when you buy it , so i think to understand what you need from this link :
    http://www.codecard.eu/carprog/subsc...s/cat_191.html
    Best Regrads
  16. The Following User Says Thank You to catalinosonesti For This Useful Post:
    laki23 (27th January, 2022)
  17. #27
    Aug 2008
    Quote Originally Posted by Dobermann View Post
    thank you !
    it will work but if you reflash with this flash and use this lib then your original is then a clone
    software is software only
    if your carprog is original then leave it original
    activations for all uses in the software are done by flash and lib
  18. The Following User Says Thank You to tango For This Useful Post:
    Dobermann (13th January, 2021)
  19. #28
    Aug 2008
    Quote Originally Posted by carradio2001 View Post
    150428CAR00542UA
    150428CAR00491KW
    Regards,
    Carradio2001.
    serial that is all
  20. #29
    Jan 2019
    Somewhere between Continents
    guys, for some reason, my carprog was triggered with the "CountDown" and some of the options / functions it goes online...
    Does anyone know if this can be sorted out by flashing it?
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  21. The Following User Says Thank You to boxsport For This Useful Post:
    anasorfi (28th March, 2021)
  22. #30
    Mar 2021
    thx a lot! =D
