Results 1 to 8 of 8
    Feb 2017
    Default VW Polo 6 Johnson Control Cluster dead help please
    Good day,
    I need some help please, have a polo bluemotion 2013 with Johnson Control Instrument Cluster that is dead (Centre display).
    Polo 6R bluemotion 2013
    Cluster: JCI 6R0920861k
    Eeprom: 95320
    SW 0306
    HW H03
    Made in Slovakia
    Any feedback or help would be much appreciated thx!
    Feb 2011
    What caused the problem?
    Oct 2014
    Netherlands
    If cluster is really dead then you might be able to get partial immo from engine ecu. Then write it to replacement cluster and learn new transponders.
    Or take a virgin(ised) cluster and let it adapt by odis (dealertool).
  4. The Following User Says Thank You to H2Deetoo For This Useful Post:
    rtbdiagnostic (10th July, 2020)
    Aug 2016
    in the zone
    Is there a way to repair the old cluster? happened to me few years ago, tried mileage change with expensive tool, not realising JC could not be done at the time. still have the old clock to experiment if someone can advise what or how to repair
    Feb 2017
    Struggling to find Replacement Cluster since it's not a common polo around my area. Dealers asking way too much for a new Cluster
    Feb 2017
    Quote Originally Posted by km666 View Post
    The owner sent it away to someone to check if coding is the problem for the vehicle not starting and owner received it back with the 95320 eeprom desoldered. I soldered back, cluster came alive except for centre display (Car does not even crank)
    Feb 2017
    Quote Originally Posted by H2Deetoo View Post
    Is it possible to reflash the main chip to a working state with other flash file if I manage to find one?
    Feb 2017
    If anyone has a saved flash and eeprom file of such a cluster I would really appreciate it to see if that will work.
    Thank you!
