Results 1 to 14 of 14
    Feb 2019
    Lightbulb Cherokee 2019 bypass
    Has anyone had success with a Cherokee 2019, if so with what equipment? I tried with the AutoProPad, which I've used for several other Chrysler cars from 2019, such as the Grand Cherokee, Compass and Renegade, but seems the Cherokee simply doesn't work at least with that equipment.
    With the AutoProPad I've done it via the Star connector using the brute force cables taping into the CAN Hi and CAN Low behind the glove compartment. Done via this method I can read number of Keys and VIN, but when I try to read PIN I get "Security Entry failed" after about 90 seconds, via OBD it's simply "Read Seed fail" right away.
    I have AVDI, but not the FCA module and a T-code I've been sort of reluctant to exchange for the Smart Pro(not a fan of tokens) and AutoProPad does most of the Cars I get to see. use AVDI only for Mitsubishi Prox on AKL.
    Hope someone can provide some additional info on their experience.
    Bishop c4's Avatar
    chess board
    the Zed-full is working with those vehicles
    camelgd's Avatar
    Jan 2011
    South Illinois
    Quote Originally Posted by DigitalBacon View Post
    Brute force cable just connects APP to system-still won't pull pin on several models of Chrysler and jeep- Jeep wrangler Sahara, for example, 2019 could not pull pin.
    APP apparently does not have program even though you are connected.
    Feb 2019
    Quote Originally Posted by Bishop c4 View Post
    So I heard, I know Zed-full is pretty good, at one point I almost bought it because I needed to do Mitsubishis Prox AKL and couldn't do it with any of my equipments, ended up purchasing AVDI for it and works flawless. Still not Convinced that my best alternative to what I already have. Those subscriptions look kind of high considering it's maybe a handful a month I'm unable to do with current equipment. But for sure it's on my mind.
    Quote Originally Posted by camelgd View Post
    Yeah that's why I'm considering getting another programmer for these cars specifically, similar to what I've mentioned I did for the Mitsubishis Prox. my AVDI is used only and exclusively for Prox Mitsubishi's and it already paid itself a couple of times. But still on the fence on what to go with.
    Really hope the guys at APP figure out the Chrysler bypass on all models soon.
    camelgd's Avatar
    Jan 2011
    South Illinois
    I would settle for now knowing that someone is actually working on the problem. Ray Ray is no longer on the project as far as I know, he's the reason why APP is as good as it is right now.
  6. The Following User Says Thank You to camelgd For This Useful Post:
    ray-ray (19th February, 2020)
    Feb 2019
    Agree, not sure if someone took his place after that or at least actively working on it, haven't heard anything about it. Looking forward to see how xhorse equipment starts making way now that ray-ray is with them, real fan of the keytools probably made 100x their cost already.
  8. The Following User Says Thank You to DigitalBacon For This Useful Post:
  9. #7
    Bishop c4's Avatar
    chess board
    Yeah I agree with you it's a bit pricey that system they have of tokens is a killer........ every single job is like a vacuum on tokens but on the positive it works decently well
  10. #8
    leandroks's Avatar
    Brazil
    does anyone know if im608 can do key programming and pin reading on those models///???
    BR
    Leo
  11. #9
    Jan 2019
    Quote Originally Posted by leandroks View Post
    BR
    Leo
    2019 Grand Cherokee
    Pin yes
    key learning yes
  12. #10
    ray-ray's Avatar
    I tried last week with my im608 & it fail to pull the pin.. l will update the tool and get back to report. APP team have hired on new help with high expectations and they all have fail to produce ( they hit a brick wall ! ) so they going to introduce 3 new units. The so call new unit can handle what new system our on the current market. BS Guys.. promise on future updates ( distributor it’s all about the MONEY ) ( when a Locksmith is in control it’s about the brotherhood )..
  13. The Following 3 Users Say Thank You to ray-ray For This Useful Post:
    darknezz19 (19th February, 2020), DigitalBacon (22nd February, 2020), milehighlockdoc (21st February, 2020)
  14. #11
    Jan 2017
    USA ����
    removing the sgw from loop with bypass cable does not work?? 12+8 cable?
    have not tried this model
    2019 cherokee prox smart pro
    https://youtu.be/O1gROf-06wo
    i see the smart pro also has the ability through the star connector so it must be solely software related to find the pin location in the data?????
  15. #12
    Feb 2019
    Quote Originally Posted by ray-ray View Post
    Yep I notice that from around mid-year last year, the updates have been less important, just smaller things(weren't you with them before?). My subscription expires in April, really thinking of leaving it as it is, since it's quite decent equipment just doesn't seem it will be doing new stuff and invest those $600 for part of a new equipment, on the fence still which one.
    Bought AVDI just for AKL on Prox Mitsubishi, since APP couldn't do it. I think I'll end up buying something new as well for these new Chrysler systems.
    Where I'm currently at don't think much people if any can do a Cherokee(not grand) 19+.
    Quote Originally Posted by sleepyrz View Post
    Yeah saw that yesterday, how quick and simple it is. Tokens are used when programming the key only? or extracting the PIN as well. I think the APP might be able to program it if you have the PIN which it is uncappable of extracing on it's own.
  16. #13
    narkeleptk's Avatar
    May 2017
    USA
    works for me with im608
  17. #14
    Jan 2017
    USA ����
    ray you try with 12+8 cable or adc2011 or bruteforce?
