Results 1 to 13 of 13
    Dec 2019
    Europe
    Default EDC16U1 - Driver wish maps?
    Hy!
    Can somebody help me to find driver wish maps in this Audi A3 1.9 tdi 77 kW, bkc engine, EDC16U1 hexdump file?
    Jun 2018
    Bulgariq
    Quote Originally Posted by davorsule View Post
    Hy!
    Upload an original file and I'll write you the addresses you need
  3. The Following User Says Thank You to naskochipa For This Useful Post:
    davorsule (10th January, 2020)
    jurebv's Avatar
    Dec 2017
    Croatia
    D1A3C
    D1B3C
    D1C3C
    D1D3C
    D1E3C
    D1F3C
    D203C
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  5. The Following User Says Thank You to jurebv For This Useful Post:
    AVDigitale (10th January, 2020)
  6. #4
    Dec 2019
    Europe
    File is in the post, do you see? If you can help me how to choose x,y and values in the map..
    jurebv's Avatar
    Dec 2017
    Croatia
    axis D19BA and D19EE
  8. The Following User Says Thank You to jurebv For This Useful Post:
  9. #6
    Dec 2019
    Europe
    Quote Originally Posted by jurebv View Post
    Zahvaljujem na pomoći... Odkuda ste?
  10. #7
    Dec 2019
    Europe
    Now I need to choose values for map, how to do that because there is some very high /65516/ values..
  11. #8
    jurebv's Avatar
    Dec 2017
    Croatia
    under map properties check "sign" box
  12. The Following User Says Thank You to jurebv For This Useful Post:
  13. #9
    Dec 2019
    Europe
    What is function of this map?
  14. #10
    jurebv's Avatar
    Dec 2017
    Croatia
    Smoke by Manifold Absolute Pressure
  15. The Following User Says Thank You to jurebv For This Useful Post:
    davorsule (11th January, 2020)
  16. #11
    Dec 2019
    Europe
    Is it neccessary to change values in this map when increasing power and torque of engine?
  17. #12
    jurebv's Avatar
    Dec 2017
    Croatia
    read some tutorials, this is very documented and explained ecu, almost every tutorial out there is about this ecu
    read!
  18. #13
    Dec 2019
    Europe
    read!
    OK, I just asked how this map is working together with smoke map as function of MAF and engine speed.
