is your headlight alway on also ?
than your eep from FRM is gone...
Take a programmer read dflash and restore eep.
Replaced new battery on 2011 BMW series 1, and now power windows don't work any one got any idea how to reset the system for windows to work again.
Note:All information given is to be used for educational purposes only and should not be taken seriously.
super jumbe (12th January, 2020)
i think frm is dead read dflash and eeprom
and post here
https://www.youtube.com/watch?v=EjVYjS8g7-M
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
Yes the headlight always on; never got across this issue because I only deal with locksmith business nevertheless there is always some thing to learn how do I read eep from FRM? Can I read with VCDS any help really appreciated thanks?
As i said u need to use a PRogrammer (Xprog, VVDI, Cgpro) depends on your devices
Look at the Video from Robert there is a example with Xprog
Than you have to read D-Flash, use a converter, and you get a eep file back... Format dflash to eep area and write back eep
Online Converter
http://tlvps.tomvanleeuwen.nl/frm/
Offline:
https://mega.nz/#!egBSVY6Z!3X2NlMTcvdn6emUgSwQ9Vdi678rUu1ugtzPbHmq SJPE
The FRM is located at driver footwell, it is behind the hood opener
Hi everyone
I hope everyone is well today
Guys I'm having a problem with my frm module and I was wondering if someone can check my files to see if they are still good .The power windows dont work, head lights stay on , indicators dont work and the car sometimes fails to start up. This happened after I had a flat battery.
I have attached 3 files as I'm not to sure if they are fine
Mc9s12xeq384
Any help would be appreciated
Thanking you in advance
Regards
What would the dealer do in such cases? Would they ask you to change that part for a new one? Any one brought that problem to a dealer?
Dealer will say that a new unit is needed.
