Results 1 to 4 of 4
    Dec 2012
    Default MB ML350 W164 2007 sometimes problem by starting engine
    Hello,
    Anyone have this problem:
    MB ML350 W164 2007 sometimes problem by starting engine... (video) When you take out and put back the fuse f14 of ezs come contact back.
    Oct 2016
    do a scan of the vehicle when it's not starting with mb star...look at actual values of ezs and live data.....that should give you a pretty good idea of where the problem is. based on the info you provided if i had to take a guess i'd say it's your ezs that is the problem. w164 have a problem with burnt out contact pins in the ezs that most of the time causes these problems.
    Thanks and Rep if I've helped you.
  3. The Following User Says Thank You to exotictoys For This Useful Post:
    rmstuning (14th January, 2020)
    Dec 2012
    Dec 2012
    Desolder all contact in ezs and same problem.
