Results 1 to 2 of 2
    Jan 2020
    Default Key Fob/Immobiliser issue
    My car is in my driveway in High Wycombe on Benjamin Road. My battery went flat which triggered my alarm, I then disconnected the battery to stop the alarm but the noise continued, throughout the day, gradually becoming quieter until it eventually stopped. I then bought a battery charger and charged the battery. When I put the battery back in the vehicle it makes a constant beeping noise until I turn the ignition. Although the noise stops the car does not react to the ignition being turned.
    Furthermore, the key fob does not lock/unlock the vehicle. I strongly believe it is an issue with the key fob/immobiliser.
    I got a quote from a garage for 300 pounds which is not worth spending.
    I would like to know if anyone could tell me if it is possible to bypass the immobiliser and what I need to do.
    Car make and model: Rover 25 SI 84 3DR (2004)
    ECU: Motorola NNN100743
    Thanks in advance.
    Luke W.
    Jan 2020
    https://remotekey.co.uk/rover/rover-oval/ does anyone know if this would fix my problem? regards
