in boot i think, drivers side
hi can anyone shed light to where the BCM2 location is for an Audi Q5 2013 year, for all keys lost situation using VVDI2 (need to remove plug half way through)
thanks!
edit - AUDI Q5
Tools owned -
sdnatlst (14th January, 2020)
Thanks. I know that is a4 a5 location
Wondered if Q5 was the same
Tools owned -
Yes is it, have a look and you'll see
Yes found thankyou.
Nothing would put the bcm2 into service mode though.
So used other method to complete.
Cheers mate
Tools owned -
u.s (18th January, 2020)
Other method? Using bdm method?
I'm sure I've done a 2014 Q5 using the unplug bcm way.
It kept saying ... 'rerun obd method'
once I unplugged bcm and plugged back in...weird
Tried 3 or 4 times....
Tools owned -
Hello guys, what keys and tools did you use if you programmed any key? I tried chinese keys, did not work.
china key worked for me
igorr (10th February, 2020)
http://www.onlyda.com/wap/product-5013.html
Here you go..
