Results 1 to 7 of 7
    Nov 2011
    Default VW golf dash ‘error’ display
    Hello
    I have a 2011 golf with error where the mileage should be.
    Is it a checksum error? The cluster works fine, all LEDs work.
    Fault code is B2000-49
    Any advise?
    brend's Avatar
    Oct 2015
    Same where
    Maybe wrong km set.
    NB!!! Don't ask in PM old file password , Im not remember.
  3. The Following User Says Thank You to brend For This Useful Post:
    rtbdiagnostic (15th January, 2020)
    keturi's Avatar
    Oct 2010
    Lievatu
    One or some warning lights broken(removed LED). Open cluster and check all LED lights.
    Sep 2015
    What happend? Was it mileage job or dash swap?
    Is it MM dash or VDO?
    Try to put different mileage.
  6. #5
    Jan 2010
    DUPNICA BULGARIA
    I think that cluster is MM. And naw you have generic checksum error. This is hapaned when you traying to recalibrate milage. Read nec and eeprom and put here.
  7. #6
    Oct 2014
    Netherlands
    If you can read eeprom+flash directly, post it here and we'll check.
    If you have no tools for that, then contact me by PM, I can help you remotely most likely.
    Rgs H2Deetoo
  8. The Following User Says Thank You to H2Deetoo For This Useful Post:
    GameTheoryOptimal (15th January, 2020)
  9. #7
    Nov 2011
    Hi everyone, thanks for the reply’s.
    So I got the car like this, I have not tried to modify.
    I have genuine xprog and genuine smok and both have problem reading chip.
    It is a MM dash, with 9s12xhz512 1M80F
    Tried reading secured 9s12 but no luck
