    dominik.m's Avatar
    Jun 2009
    POLAND
    Default Mercedes Vito 2.2CDi EDC17C66
    Hi All.
    Mercedes Vito 2.2CDi EDC17C66 0281031244 A6519002803
    Someone can help remove Adblue and DTC P2201 ?
    Need tested solution
    Mooti's Avatar
    Nov 2018
    Is this an error from the temperature sensor?
    dominik.m's Avatar
    Jun 2009
    POLAND
    This is a dtc from the NOX sensor. I have already replaced both probes and it repeats every few hundred kilometers.
    Mooti's Avatar
    Nov 2018
    Is it better to remove NOX from the map? I have no solution on adblue off. But maybe someone in the forum will do it
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by dominik.m View Post
    Hi All.
    here you go
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  6. The Following 4 Users Say Thank You to Ignasvw For This Useful Post:
    dominik.m (16th January, 2020), immokill (10th February, 2021), kinketotua (16th January, 2020), stanislav georgiev (16th January, 2020)
    dominik.m's Avatar
    Jun 2009
    POLAND
    Thank You. I will test and report.
