Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
  1. #31
    Jan 2013
    Quote Originally Posted by yarowsc View Post
    post here both dumps
    Something's wrong here. "SAFE" is shown when there is no active Immo key, but in RB8 counters, under Immo4.
    in Immo3 and 3.5 after connecting the cluster and the without an active key, you can normally see the current total mileage of the car
    Hello
    Here are both dumps read with vageepromprog 1.9.
    What if i just write another encrypted eeprom from a different tacho but same part number ?
  2. #32
    Nov 2018
    Poland PL
    then the display will show "def" or "error"
    it is unlikely to follow the cluster replacement procedure with Ross-Tech.
    the best solution is to rewrite the "Immodata" file, but to do this you need VDC, Smok, AVDI - org., not china
  3. #33
    Jan 2013
    Could be somthing wrong with the new tacho?
    Sent from my SM-G925F using Tapatalk
  4. #34
    Jan 2013
    Could be a crypto or non crypto problem ?
    Or tachos are both crypto ?
  5. #35
    Jan 2013
    Quote Originally Posted by armi View Post
    Possible solution for SAFE. Set new mode. Connect to cluster with VCDS, without inserting new cluster pin go directly to ch 50 , and use old pin to adapt to immo, then go directly (do not exit controller ! ) to ch 21 and adapt keys. Set back to mode 6.
    SAFE shows dismatching cluster to engine ECU or keys to cluster. Good luck!
    Tried no succes
  6. #36
    Aug 2015
    Latvia
    What VCDS tool you use to make adaption, china , ori, and what program version?
  7. #37
    Jan 2013
    Tried a different tacho(no color) and it worked. Adapted immo and keys.
    Whats the problem?
  8. #38
    Aug 2015
    Latvia
    I have no ideas now why adaptation does not go right.
  9. #39
    Jan 2013
    Weird
  10. #40
    Aug 2015
    Latvia
    What error codes is now in cluster and in engine ECU?
  11. #41
    Jan 2013
    I put the old tacho back and cleared all faults didnt even looked
  12. #42
    Jan 2013
    Old and new tacho.still havent managed to make it work
