Results 16 to 30 of 37
  1. #16
    Dec 2018
    когда ключ карты вставлен, он считывает данные булавки из него
  2. #17
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by Catalizator View Post
    No, because i don't plug any card inside HFM.
    so the PIN and ISK is not from card.
  3. #18
    Dec 2016
    Quote Originally Posted by didi_du_93000 View Post
    I have problem too.
    Renault Capture 2018.
    The HFM is virgin. But RET give me ISK and PIN.
    From where he read ISK and PIN if HM is virgin???
    today same car same year , i accidentally push "reset HFM" buton , car was in official Renault dealer : official CAN-clip failed to program HFM + existing card ( "blank card error" , but no blank ) , Renault Ecu Tool provide me ISK + PIN code , i finish job with R.E.T with this codes
    Happy end for me ! why is possible ?
  4. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (28th August, 2020)
  5. #19
    scotland clydebank
    Can Terminator explain since he knows more than most as I still not get it thank you
  6. #20
    Dec 2016
    Quote Originally Posted by godfathertre View Post
    #me too !
    1° Dealer call me to add card Captur 2018 .... he talk me about his life problem .... distract me ...
    2° I reset to virgin HFM by error : FATAL ERROR > can not learn cards > HFM virgin message !
    3° he connect CAN CLIP to program HFM + OLD CARD : he failed with message "blank card error" , but no blank card
    3° i connect R.E.T for write V.I.N to help > V.I.N already write !!! ( by can-clip ? )
    4° i test lear HFM > ISK & PIN code appear in screen of R.E.T
    5° I input this codes > step one : learn old card ( to program HFM ) > steep two : learn new +old card
    i don't understand if R.E.T REALLY VIRGIN HFM or if is CAN-CLIP beginning to learning HFM and failed ...
    but i think R.E.T use this bug in system for learn card after 2015 ( 99% sure ! ) and other tool to theft cars AKL after 2015 ) with pre-code ISK in virgin card
  7. The Following 3 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    galisdoo (1st November, 2023), godfathertre (4th February, 2020), helmi reguig (28th August, 2020)
  8. #21
    Apr 2013
    Reunion
    Its possible to learn HFM with smok ?
  9. #22
    Top Poster admiralx's Avatar
    Apr 2012
    Quote Originally Posted by seat130 View Post
    not possible
  10. #23
    Jul 2013
    Pandora
    hi,
    why not?
    smok has released some update about renault car
    http://smok.com.pl/index.php?id_prod...duct&id_lang=2
    for information, when you use RET for virgin hfm, isk is still present. Virgin not means virgin isk but means "ready to code new isk"!
  11. The Following User Says Thank You to lagaffe For This Useful Post:
    TERMINATOR1000 (1st September, 2020)
  12. #24
    Dec 2016
    Quote Originally Posted by lagaffe View Post
    hi,
    why not?
    (option available from 27.07.2020)
    NEW UPDATE
    - Key programmer Key Maker V2 = 400€ ( for AKL 2016+ )
    - RT0031 Renault Card Programing in HFM Module OBD = 240 €
    - Interface Multitool UHDS+OBD cable = 130€
    thanks for info .
  13. #25
    scotland clydebank
    So is this the solution we are looking for can we program with all lost keys and no working card and will this work for flat battery yes or not.
  14. #26
    Dec 2016
    for flat battery NO , only Renault.net can do it , all data are lost definitely . For AKL need to test SMOK for already user of this tool ???
  15. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (2nd September, 2020)
  16. #27
    scotland clydebank
    Surely Renault should pay if flat battery and car not start why are they not liable since this should not happen to new models of cars.
  17. #28
    Dec 2016
    it's not an expensive OP , 40-80€ , yes it's anomal breakdown , towing & delay to repair car it's more boring
  18. #29
    Apr 2021
    HI, Does someone can provide a clear virgin dump for HFM? Which will be a ready to learn HFM. I'll try to code with dump from head but receive "7f3122 conditions not set or sequence error". So I guess this is not possible to learn HFM with this dump.
  19. #30
    Jul 2015
    Quote Originally Posted by TERMINATOR1000 View Post
    I confirm is blank , need online coding , no ISK no PIN code inside !
    compare to no blank HFM ;
    hi
    Ecu Tool will read the real isk and pin from bcm on phase 2 models and then can use a transponder read write tool to make correct pre coded card
    and then use to relearn hfm and learn card
    demo is here on video on how ot use lock50 tagpro to precode card with pin in 1 click and use to relearn hfm back
    https://lock50.co.uk/tagpro/sw-01-re...nown-pin-code/
