Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Check all once again. Do you put back 0ohm resistor?
    IF I HELPED YOU PRESS THE " T " BUTTON
  2. #17
    May 2016
    lithuania
    maybe anyone has full bsi dump??? not only eprom
  3. #18
    May 2016
    lithuania
    yes resistor is in place
  4. #19
    PSAcars's Avatar
    Oct 2015
    HOME
    Does the car start? If yes you dont hahe problem in BSI. If no problem in BSI. If car start and dash is not working try other dump in dash, fimd some here and test them in your car. Find instructions for enigma programmer how to connect to BSI not on res.matric but on other ic in board. No pin lift of main cpu.
  5. #20
    May 2016
    lithuania
    car starts, i have allreadi tried original dumps from bsi and dash,but doesnt help...
  6. #21
    PSAcars's Avatar
    Oct 2015
    HOME
    Try other dash dump, not yours, find someone else file.
  7. #22
    May 2016
    lithuania
    i have tried lots of i think i need full bsi dump
  8. #23
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. What tool are you useng to read and write the nec mcu, maybe bad write. Old necprog is made for this mcu and works 100%. I had the same problems 10 years ago with my father picasso, made programmer and write nec resset eeprom file, and good not mine dash file, and till this day the car is ok.
  9. #24
    May 2016
    lithuania
    i am using upa china clone
  10. #25
    May 2016
    lithuania
    Solved!! changed bsi and wrote mine nec dump with reset. and cluster dump calculated with nyo4
  11. #26
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Congratulation nahalaz, good work.
  12. The Following User Says Thank You to PSAcars For This Useful Post:
    nahalaz (1st March, 2022)
