Hi guys,
In the near future I would like to convert AGR 90 Hp wastegate to vnt controlled.
Will it be okay if use immo off ALH 90 Hp file it is VNT controlled.
Can I just upload OBD an immo off file? (012 Vag number so OBD ready.) Or need to solder eprom to off immo.
(made with software to make immo off by flash)
Thank you very much any help appriciate
I thought that read the software by OBD and modify the flash with immo off software and upload it for the car. Hope to start, if not I need to desolder the eprom from the ecu and make an immo off by traditional way
Update - It was easy to load another Golf 4 ALH sw into it, to handle VNT no need to do immo off.
After for some reason I made the VNT file from ori AGR file.. by this I learn where PID-s and how Turbo control works.
Any tool can handle this VM+ ECU for example Kess V2, Galletto V54 and MPPS.
Thank you for help
