Results 1 to 15 of 20
    Default Skoda fabia 2007 year 1.2 petrol engine
    Hello
    I done KD x2 chip 48 clone fail ecu locked
    03e 906 023 d
    Simos ecu 9.1
    Lock time?
    Help please
    super jumbe's Avatar
    Livingstone
    Have you got vvdi2 tool if not can you list all tools we may able to help you.
    Dec 2010
    Nottingham
    if you was only cloning a key and it cloned fine , but ecu locked then it may be just a blip .
    when sniffing the data from the car , did you switch ignition on and off with programmed key or with the new key ?
    if with new key then how many times did you give ignition on and off ?
    if you have cycled an unprogrammed key too many times in the ignition then ecu will lock , keyline uses used to sniff with the gkm or tkm head and if cycle too many times they locked ecu , with keyline they now tell you to cycle with original key holding gkm near ignition at same time , if locked due to this then a simple soft reset will fix it
    if now not starting on original key then insert original key in ignition and switch ign on to position 2 when dash lights up , leave on for 45 minutes , after 45 minutes switch off and remove key , now reinsert original key again and try and start car
  4. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    just4upal (18th January, 2020)
    Livingstone
    Quote Originally Posted by kenancatli View Post
    Hello
    03e 906 023 d
    Simos ecu 9.1
    Lock time?
    Help please
    Lots of people had similar issue cloning with KD-2 tool the key data is wipped out can you read key data?
    scotland clydebank
    I had this with keyline Ultegra
    Sniffing a id 48 on audi tt the car thinks is getting stolen so alarm sounds and lock time disconnected battery did not help thank to the vcds original codes where cleared and car started more likely a fault code these vag the trough faults everytime so a must is to have vcds when doing vag vehicles best tool for what it does.
  7. The Following User Says Thank You to godfathertre For This Useful Post:
    p1et (18th January, 2020)
  8. #6
    Hello
    I have vvdi2 full version, I try first vvdi2
    Vvdi2 can't connect.
  9. #7
    I try and report
  10. #8
    Dec 2010
    Nottingham
    if just cloning then only thing that would lock the ecu is if you have turned ignition on and off too many times with an unprogrammed key whilst sniffing data , soft reset of ignition on with original key for 45 mins would clear this if the case.
    if kdx2 has wiped original key then thats a bad flaw with kdx2 , but if a flaw of the machine then im sure this issue would be plastered all over the internet and common knowledge .
    vvdi2 not getting comms with ecu is another ball game , check fuses and power to obd , i take it that the original key was starting the engine before you tried to clone it ?
  11. #9
    Problem solved,
    Vvdi2 orginal full version, can't add key, can't read eeprom!!! Fvdi2018 can't, I read ecu on bench, find pincode,vcds can't add key!!! add key with obdstar dp successfully. Fk kdx2 tools 100% brick immobiliser!!!!!!
  12. #10
    Apr 2016
    uk
    Problem solved,
    I do not clone much but when I have to,kd served me well.
    Never had any issues with it.
    Depending on the engine,if petrol vvdi2 cannot read ECU,fvdi neither.
    But,vvdi2 can read pin from cluster, depending again from what engine is on the car.
    If your vcds cannot add key it means you have a bad clone. Done plenty k-line cars with vcds no issues.
    So,don't blame the tools, sometimes you need to know which one and how to use it!
  13. #11
    Hello
    Kdx2 good for remote , transponder clone id48 risk!!!
    I have always clone do with handy baby never problem no risk!!! Do wrong or not wrong , no risk.
    I have not wrong done, kdx2 big problem!!!!
  14. #12
    Apr 2016
    uk
    Hello
    As I said,I done clone much but never had problems with it and never heard anyone having this problem.You are the first one I hear!
    You still don't want to tell us what you done to the car..
    You still did not answered to @rapid,how did u sniff?
    And,as @rapid says,ECU will not lock if u use a working key!
    Also,if ECU gets locked is very easy to unlock,just keep ignition on for 45mins.
    What did damage kd?
  15. #13
    p1et's Avatar
    Oct 2013
    Hello
    So why not clone with handy baby this time then?
  16. #14
    Apr 2016
    uk
    Quote Originally Posted by p1et View Post
    Haha,
    Good question @p1et ..
  17. #15
    I have try handy baby not success!!!
