    Jan 2020
    Default How to clone a BMW ECU ME9.2 with BMD100
    Hi there,
    I'm unfortunately an absolute beginner.
    I would have to clone the following ECU
    BOSCH ME9.2 from a BMW e46 318i
    Today my ordered BDM100 has arrived.
    I wanted to connect the BDM100 directly to the ECU with wires.
    Which pin of the BDM100 do I have to connect to which point on the ECU?
    It would be nice if you could help me.
    Thank you
    Regards Dieter
    May 2017
    mate... use search function.
    You cant use only bdm by bdm100 china tool ... need extra wire, you wil find by research.
    With ori tools no problem at all.
    Jan 2020
    Thank you for your answer.
    Do you mean the extra power supply with extra cables?
    I found the following Picture.
    But there are lines that I don't have with the BDM100.
    What are Ori Tools?
    As a beginner, it is not easy to see through there.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Check this out. It always works correctly.
    May 2017
    http://blog.eobdtool.co.uk/readwrite...og-and-bdm100/
    look unter point 3... read no big deal, write more important.
    Clone tools often didnt write last 1%.
    Jan 2020
    Thank you both for the info…
    Unfortunately I can not load the file. I have no authorization.
    But I just managed to read and write the ECU myself.
    I had not properly soldered a 12v wire.
    Thanks and Greetings
    Dieter
