Results 1 to 15 of 47
Hybrid View
    Dec 2010
    Nottingham
    Quote Originally Posted by super jumbe View Post
    Just checked on Instacde database all you need is the code.
    Vehicle: MCC ForTwo
    (Gen1) 1998 to 2006
    YM31
    Series: HY6001 - HY8130
    if you look a little closer , HY6001 to HY8130 on ic card 74 is not for the 8 cut smart fourtwo , this series is for a much older 10 cut key used on mercedes models 1977 to 1985 , as a 10 cut key it use very different spacing , so you will not cut an accurate key using this series for smart fourtwo . smart fourtwo uses ic card 1896 , using different space info , so of no help on smart .
    so having the code still wont help you , just getting the code wont help unless you are working on an old mercedes 1977 to 1985 !
    if your instacode lists this as a valid series for smart fourtwo then its incorrect and will lead you wrong , which isnt uncommon as instacode for many years listed smart fourtwo 2006 on as VA2 ABCDEF series on ic card 1049 , fourtwo never used this series , its only recently that they changed this to the correct series.
    if wanting to do all keys lost on these old smart fourtwo models then you will need the lishi YM23 8 cut pick and decoder , or remove and strip locks to read cuts , and of course a machine that can cut the 8 cut key using ic card 1896
