Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    ghostrider72's Avatar
    Jul 2012
    UK
    Quote Originally Posted by newone View Post
    drill the pin remove spring and safe and it will be apart
    You mean this pin on the back mate?
    There is only one on that lock
    Regards
  2. #32
    newone's Avatar
    Oct 2016
    yes,drill that pin and lock will be at pieces
    pay attention to drill the pin good,after that you press the release safe up and there will be a spring under it,do not use strong pressure pulling the release safe as there is danger to crack,it will take some time as it is your first time but the next will be very quick,i repair a lot of these after steal attempts
  3. The Following User Says Thank You to newone For This Useful Post:
    ghostrider72 (6th February, 2020)
  4. #33
    Mar 2009
    how do you remove the ignition barrel without a key???
  5. #34
    Meat-Head's Avatar
    Quote Originally Posted by mr501 View Post
    Dunno, one would guess starting with pick it, but not the same way Michael Jackson would pick his nose.
  6. #35
    szengen's Avatar
    Jan 2017
    Poland
    Default fiat
    Quote Originally Posted by Meat-Head View Post
    fiat 10 minut
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  7. #36
    Nov 2015
    UK
    Getting some information from this group & trial & error ive now been able to cut a Silca YM23 key for a smart car 2001
    I have taken the ignition lock apart to find the wafers stamped as follows.
    65 67 65 66 65 66 68
    So forget the first digit of which you now get 5 7 5 6 5 6 8
    The YM23 file in Codemaster 5.56 uses numbers 1-4 so subtract 4 from each number mentioned so 5 7 5 6 5 6 8 becomes 1 3 1 2 1 2 4
    The ignition lock has 8 wafer spaces BUT only 7 wafers are used.
    I cut the key on my Miracle A5 & the type of key "YM 23" is attached
    Many of you know that YM23 profile isnt shown in Instacode so here is my file to share for you.
    https://drive.google.com/file/d/1GWX...ew?usp=sharing
    Hope this helps.
    Simply paste this file into the Smart Car folder within Automobiles.
    Then open Codemaster to see the file is now shown as YM23 OLD TYPE
  8. The Following User Says Thank You to Buddy41 For This Useful Post:
    alex_r_2001 (5th June, 2021)
  9. #37
    Aug 2013
    Spain
    I have here the a trunk lock from smart fortwo all keyst lost. I decode with lishi YM23 and give me this 7 cuts 3343431 i change the cut to 7787875 and try find bitting in instacode without success i cut key but not luck with this. Is possible dissable trunk barrel for read wafers? How can extract this?
  10. #38
    Dec 2010
    Nottingham
    i would revisit your decode to see if decode is wrong which is likely as not working.
    decode in same direction as picked , very gently push along line till you touch the wafer then gently push past the spring to the stop position to get your reading .
    be sure your machine is cutting the generic number 5 cut in position 8
    instacode has alot of missing codes so isnt always much help on these
  11. #39
    Nov 2015
    UK
    I think the wafers are marked like so.
    65 66 etc
    Can you post that ?
  12. #40
    Aug 2013
    Spain
    yes, i read in same direction as pick. trunk lock barrel can be extract for read wafer?
  13. #41
    newone's Avatar
    Oct 2016
    Quote Originally Posted by carsandkeys View Post
    press here pin inside and pull cylider out
  14. The Following 2 Users Say Thank You to newone For This Useful Post:
    carsandkeys (10th April, 2023), rob h (10th April, 2023)
  15. #42
    rob h's Avatar
    May 2011
    What i do when i pull the core:
    Before i slide out the shims,
    Insert a new blank key, and measure the height they stick out first.
    If for some reason, a shim gets launched, or more then one falls out. You will still have pretty good idea, what goes where.
    And it could give you the code, without pulling the shims. If measured correct.
    You could insert a lishi, lift the shim so it alignes with the core. And write down this code.
  16. #43
    Aug 2013
    Spain
    i try without success. Solved after 2º decode. 2 wafers change hight from 3 to 2.
  17. #44
    Dec 2010
    Nottingham
    as stated , it was the initial decode . always worth decoding a few times to be certain of decode.
  18. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    qwojtus (12th April, 2023)
  19. #45
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    If you are close to Burnley I have a gearlever you can have with two keys (no electronics unless I can find some).
    No matching tailgate lock though.
