Results 1 to 15 of 17
    fordobd's Avatar
    Jun 2012
    Default BMW E60 eeprom 35080 dash is DEAD
    After change battery on car eeprom 35080-6 dash is DEAD
    Need file for 35080 car is 2003 E60 530d 290.000KM manual shift
    vdo 0.080.213
    BMW 62.11-6 9317 618
    WBANC71030B140615
    THANKS
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Read the 35080 with a good programmer,so i can check your dump
    fordobd's Avatar
    Jun 2012
    Hello
    seven programmers and the reading is 000000000000 or FFFFFFFFFFFFF
    upa, gQ4x, carprog, xprog, willen, orange4, ttl886
    install another instrument cluster and reprogram with ista-p but gear change error
    fordobd's Avatar
    Jun 2012
    wrote another similar file in a 35080 vp whit tl886
    program instrument cluster with ista-p but it gives error gearbox in display
    pepi's Avatar
    Quote Originally Posted by fordobd View Post
    vdo 0.080.213
    WBANC71030B140615
    THANKS
    Try this dump it is with manual transmition and ready for coding.
  6. The Following 3 Users Say Thank You to pepi For This Useful Post:
    balikci (30th March, 2020), fordobd (18th January, 2020), morgano (18th January, 2020)
    fordobd's Avatar
    Jun 2012
    the file is not good don't let write in EEPROM
    another file yes
    Cllau's Avatar
    Mar 2017
    where friends need me
    another file yes
    what toll are using to write....?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    tl886 programmer is not good to work on 35080.
    This programmer reads good but only can write if you increase the data. If you want to write new information with lower mileage in eeprom 35080 using tl886 programmer....that will not be possible because tl886 doesn't erase the first lines.
    You will need m35080 programmer or similar
  10. The Following User Says Thank You to jomberykaso For This Useful Post:
    rafal (19th January, 2020)
  11. #9
    levisdj's Avatar
    EcuLand
    R270 also erases INC area on 35080 6 eep
  12. #10
    fordobd's Avatar
    Jun 2012
    testing with another digiprog 3 read eeprom dead car
  13. #11
    pepi's Avatar
    Use new eeprom .
  14. #12
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I believe your read is good not bad.
    But if you have time:
    This dump e60 2004 3.0d manual transmision,code with ncs expert in expert profile KOMBI.otherwise your car should be with same options- saloon,no active steering,no dynamic drive,no cruise radar
    It has your kms and your vin
    Write full then verify,if its not same,use new eeprom.
  15. #13
    fordobd's Avatar
    Jun 2012
    the problems continue, the PEPI file worked fine after encoding it with ista -p, but when moving the car the background of the screen shines brightly and the numbers are devoted
  16. The Following User Says Thank You to fordobd For This Useful Post:
    alhoceima (29th December, 2023)
  17. #14
    Mar 2022
    Paris
    Hey thanks stelaras you just saved my night with this file, this f****g dp4 just corrupted a dashboard bmw E60 because of a bad eeprom clip connection
    it's midnight on a mcdo parking and it's been 45min I wonder what's wrong with the dash
    anyway a happy new year
  18. #15
    Nov 2018
    Minecraft
    @alhoceima, DP4 can break 35080, use other tool
