carmageddon big thank, but my device is not working
Start ksuite v2,08 , but update does not want to run ( SD card is new 16gb format FAT32, no internet connection)
where is the problem?
I think, i need update file : SD card , update to k-suit, npx bin if necessary
I have red version K-tag v7.020 EU clone, which was blocked after connecting to the Internet
this is simply clean 2.08 version for firmware 4.036 kess.
is not able to reset token without config file or relive nxp after connection to internet...you need also reset config file (token reset)...but i think that you need to change nxp after connection to internet.
ktag 7.020 and kess 5.017 dont have problem with internet connection, you can use it with internet ON...only previous version (ktag fw 5.xxx/6.xxx and kess fw 3.xxx/4.xxx) have this problem.
sd card max 4 gb.
here is reset token, maybe can solve your problem
each time you need to try an update you MUST change sd card.
https://mega.nz/#!ioAQgQrZ!Rd1ny-_GD...ejjKQYVyMijZrY
a17h641a (19th February, 2020), dehacko (3rd February, 2020), MANGAESY (15th February, 2022), MOBILTRONIC (16th February, 2020), whalla (25th February, 2020)
Thank you again for you time. My problem was that I used ksiute 247 which is great for kess, but not suitable for K-tag
For K-tag I use version 223 ksuit
K-tag is already ussing succesfully
hello everyone, can someone help me. You KTag and Kess boxes with all accessories, but the software does not run under windows 7, what can or do I have to do that I get the boxes to run. Thank you
