Results 1 to 9 of 9
    Jan 2020
    Default Engine doesn't start after changing the fuse box
    Hello, I have an 2012 Alfa Romeo Giulietta 1.6 Diesel and I recently changed the fuse box, but now the engine does not turn on when turning on the ignition. All the lights and radio starts however, only the engine does not start. Does anyone knows why it wouldn't start?
    Thanks.
    Last edited by nicku29; 18th January, 2020 at 07:49 PM. Reason: spelling(*Giulietta)
    right here right now
    Can you post a photo of the fuse box that was replaced
    Sent from my H8216 using Tapatalk
    Jan 2020
    Quote Originally Posted by smokinjoe View Post
    I only have a picture of the back label of the old (original) fuse box:
    Attachment 683136
    The new fuse box (front):
    Attachment 683137
    They are nearly identical on both front and back, however, on the back label of the new fuse box, the code reads "Y503440350114" instead of "
    Y503440350116" on the old one. I will try to provide as much information as I can so if you need anything else, I will upload more pictures. Thank you.
    sorry i cannot open your attachments,just wondering if its the interior fuse box that you replaced and if similar to older models maybe the bsi is attached to the fusebox and maybe the car is now immobilised?
    Aug 2018
    Romania
    smokinjoe is right. That is not just the fuse panel but also BSI inside. What defect did the car with the old module initially have?
    Jan 2020
    Yes, it was the interior fuse box.
    Quote Originally Posted by sebage View Post
    The deep main lights did not work even after changing the bulbs and fuses.
    Is there a way to rewrite the BSI? Thank you.
    Open up the bsi and check for any damage which may be repairable on original , if you want to transfer immo data check to see wether it has eeprom or mpc, if it has eeprom then just swap them from old unit to new
    Meat-Head's Avatar
    PARTLY ON TOPIC:-
    go stalk member “yellow stilo” mind of information
    Sep 2015
    that's not only fusebox but also BCM (body control module), all keys, immo info and car configuration is inside so no wonder it won't start
