Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Dec 2019
    Default Grand Cherokee 2011 - Panic mode as soon as battery is connected!
    A local “mechanic” forcefully pushed in the start button into the key fob slot and the pulled it with claws or a hammer and it got destroyed.
    I replaced the whole module and now I would like to connect my scanner/pass trough and program it. The problem is that originally the car would not turn to run/on and the horn and lights keep flashing/active.
    I was thinking that I should be able to communicate and program the old key but since the ignition is not switching to on, the OBD2 does not have power.
    I have tried unplugging the battery and tested the fuses. Also, the car keeps flashing lights and horn just as Panic mode even with the old module.
    Mar 2018
    UK
    you dont need ignition ON to have 12V on the OBD - OBD always must have 12V - if there isn't power check the fuses
    if you have power on the obd but dont have comunication you can force ignition ON
    - short OBD pin 1 to pin 16
    or
    - find the ignition relay and short it
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Meat-Head (21st January, 2020)
    Meat-Head's Avatar
    Quote Originally Posted by Manta1600 View Post
    Would like to err on side of caution bmw vw group yes do it
    jeep and scum of the earth a little twitchy doing that.
    fiat is a deffo no no as canbus!
    link fuses instead, or if cigar lighter ign fed, feed that instead
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
    Manta1600 (18th January, 2020)
  6. #4
    Dec 2019
    I do have power on the OBD2 port but no communication.
    I will try to short the ignition relay.
  7. #5
    Dec 2019
    I returned to the car today. There a lot of relays related to the ignition. If some can tell me where the anti theft module is, I will gladly remove it in an effort to bypass it.
  8. #6
    Dec 2019
    I request some reinforcements "an actual mechanic" and he did something near the fuse box that actually turned the instrument cluster on and the ignition. I was able to connect to the can network and program the replaced module. However when trying to program the key with my autopropad; it says "programming success number of keys 0" and the keys are not programmed at all. Any suggestions on how to proceed please?
  9. #7
    Jan 2019
    are you trying to program a new key or a key that was already used?
  10. #8
    Dec 2019
    I tried to program the old key, I can return to program an old one if needed.
  11. #9
    Jan 2019
    if you install a new immo module, or erase all key
    you must either A) renew key or B) program virgin key
    key becomes locked when paired to module
    maybe you can dump old module and write to new module eeprom but this I have not done on that particular system
  12. #10
    Jan 2017
    USA ����
    USE NEW KEY
    The thanks button is HERE looks like this --->>> THANKS
  13. The Following User Says Thank You to sleepyrz For This Useful Post:
    Krazyglue354 (31st January, 2020)
  14. #11
    Dec 2019
    Update: new key does not program either. It is weird that the new module pin code is 0000
  15. #12
    Dec 2019
  16. #13
    Jan 2019
    are you using micropod? dont think pin code can be 0000
  17. #14
    Jan 2017
    USA ����
    Ive seen it be 0000 but that was an older car.........
  18. #15
    Jan 2017
    USA ����
    Have you scanned for codes to see if its not screaming what the problem is
