Results 1 to 5 of 5
    Jan 2020
    Default Infiniti Q30 Fault code B3009
    Good morning, I have an Infiniti Q30 AWD 2.2d, year 2016. I have the fault code B3009 and I can't find information about it. The Bosch diagnostic machine says it is the cluster lighting regulator and Launch says PWM output ill. Someone has had the same problem and how it has been solved. Thanks and regards
    keturi's Avatar
    Oct 2010
    Lievatu
    Lighting regulator and PWM output ill is the same thing. "Lighting regulator" - for housewfe, PWM output ill - for engineer
    Jan 2020
    Could it be the cluster voltage regulator? Anyone have the cluster scheme of W176, W246 or GLA? They are the same car. Thank you
    Jan 2020
    I have two cars with thw same problem. Nobody can help me? Thanks
    Meat-Head's Avatar
    Start with what is tge problem from the drivers point of view?
