Results 1 to 3 of 3
    Aug 2019
    Default need coding for ABS Audi A3 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AE
    Audi A3 manual 2.0l 2009 4 cyl hatchback
    Monday,09,December,2019,11:13:18:39744
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    www.Ross-Tech.com
    VIN: WAUZZZ8P69A048979 License Plate:
    Mileage: 98440km-61167mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56
    VIN: WAUZZZ8P69A048979 Mileage: 98440km-61167miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: AUX7Z0H8FNH0U6
    Coding: 0103000C180F0060
    Shop #: WSC 01357 011 00200
    VCID: 72EC018A6D3461D1EF-8026
    2 Faults Found:
    012691 - Intake Manifold Runner Control
    P3193 - 002 - Open Stop outside of Valid Range
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98449 km
    Time Indication: 0
    Date: 2019.11.28
    Time: 20:09:43
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 18.0°C
    Temperature: 19.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 12.065 V
    000256 - Mass Air Flow Sensor (G70)
    P0100 - 004 - Supply Voltage - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98449 km
    Time Indication: 0
    Date: 2019.11.28
    Time: 20:09:43
    Readiness: 0110 0001
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0109
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 00003 329 177603
    VCID: 75E63A96DC5A76E9CA-8020
    3 Faults Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 320
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 195
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
    Component: KlimavollautomatH09 0100
    Revision: 000068 Serial number: 8P0820043BG
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    01336 - Company Data Bus for Comfort System
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 10
    Mileage: 98396 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008957476
    Coding: 118E0F0780141380EF00000A4F00000000084E056406000300 2000000000
    Shop #: WSC 06314 000 08192
    VCID: 489883623B28BB0161-801C
    Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    3 Faults Found:
    00988 - Lamp for Brake Light; Right (M10)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 90583 km
    Time Indication: 0
    Date: 2018.10.27
    Time: 01:51:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    OFF
    ON
    OFF
    OFF
    ON
    01496 - Bulb for Fog-Lamps; Left (L22)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 90583 km
    Time Indication: 0
    Date: 2018.10.27
    Time: 01:51:00
    01500 - Bulb for Fog-Lamps; Right (L23)
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 196
    Reset counter: 233
    Mileage: 92480 km
    Time Indication: 0
    Date: 2019.04.22
    Time: 22:07:00
    Freeze Frame:
    ON
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142413039303030344A55304C38503053
    Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_Airba01AURB4 001001
    ROD: N/A
    VCID: 499E8666E82242097E-801C
    Subsystem 1 - Serial number: 34928RB4000044B0387J
    Subsystem 2 - Serial number: 35028RB4000041AC89CU
    Subsystem 3 - Serial number: 35128RB4000044B0C22A
    Subsystem 4 - Serial number: 35228RB4000041AB7D4Q
    Subsystem 5 - Serial number: 35547RB40000461CD5AV
    Subsystem 6 - Serial number: 35647RB40000461CDBE%
    No ASAM data for: "EV_Airba01AURB4" (AU35)
    No fault code found.
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000012
    VCID: 78F833A20B480B81D1-802C
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 932 HW: 8P0 920 932
    Component: KOMBIINSTR. VDO H18 0830
    Revision: D0H18006 Serial number: 2248H006002325
    Coding: 0005128
    Shop #: WSC 01286 386 00064
    VCID: 71EE0E8668325AC916-8024
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K08919082E
    Coding: E9831F061002020100
    VCID: 3566FA965CDA36E90A-8060
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 233
    Mileage: 90098 km
    Time Indication: 0
    Date: 2018.09.19
    Time: 03:37:16
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    VCID: 4382944E020E9859B4-8016
    1 Fault Found:
    00625 - Vehicle Speed Signal
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 29
    Reset counter: 6
    Mileage: 97286 km
    Time Indication: 0
    Date: 2019.08.22
    Time: 22:08:25
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H18006 Serial number: AUX7Z0H8FNH0U6
    Shop #: WSC 00137 211 56823
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0060
    Coding: 0004148
    VCID: 428C914A1D149151BF-8016
    3 Faults Found:
    01706 - Switch for Mirror-Adjust (E43)
    008 - Implausible Signal
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    00109 - Left Mirror Turn Signal Lamp (L131)
    012 - Electrical Fault in Circuit - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 234 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5CD9EA8564691197-807E
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 50
    Reset counter: 24
    Mileage: 98422 km
    Time Indication: 0
    Date: 2019.11.24
    Time: 21:25:26
    Freeze Frame:
    Voltage: 14.13 V
    DU
    Temperature: 28.0°C
    RPM: 2163 /min
    Speed: 57.0 km/h
    Speed: 57.0 km/h
    Count: 0
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1880200002186D2D8505488AC677
    Shop #: WSC 00000 000 2088960
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    01403 - Glass-Break Sensors; Rear
    011 - Open Circuit
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serial number: 30659850321912
    VCID: 3460C79257A02FE13D-8060
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0004148
    1 Fault Found:
    00110 - Right Mirror Turn Signal Lamp (L132)
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 J
    Component: Dynamische LWR H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000013
    VCID: 418E9E4618128A49A6-8014
    2 Faults Found:
    01291 - Rear Left Side Airbag Shut-Off Key Switch (E297)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 10
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 84776 km
    Time Indication: 0
    Date: 2017.09.03
    Time: 01:36:18
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Priority: 10
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 84776 km
    Time Indication: 0
    Date: 2017.09.03
    Time: 01:36:18
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
    Component: R Concert2+ H03 0270
    Revision: 00H03000 Serial number: AUZ1Z3H3472153
    Coding: 0110211
    VCID: 3F8A98BE6EE6FCB9D0-806A
    End-------------------------(Elapsed Time: 02:05)--------------------------
    Jul 2013
    yorkshire
    You might get better results if you ask in car section! This is truck and tractor.
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Quote Originally Posted by localmode View Post
    www.Ross-Tech.com
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98449 km
    Time Indication: 0
    Date: 2019.11.28
    Time: 20:09:43
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 18.0°C
    Temperature: 19.0°C
    Voltage: 12.065 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98449 km
    Time Indication: 0
    Date: 2019.11.28
    Time: 20:09:43
    Revision: 00H35001
    3 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 320
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Time Indication: 0
    Date: 2019.11.28
    Time: 22:15:08
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 195
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 10
    Mileage: 98396 km
    Time Indication: 0
    Freeze Frame:
    ON
    Coding: 00056595
    Shop #: WSC 06314
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 90583 km
    Time Indication: 0
    Date: 2018.10.27
    Time: 01:51:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    OFF
    ON
    OFF
    OFF
    ON
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 90583 km
    Time Indication: 0
    Date: 2018.10.27
    Time: 01:51:00
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 233
    Mileage: 92480 km
    Time Indication: 0
    Date: 2019.04.22
    Time: 22:07:00
    Freeze Frame:
    ON
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    ROD: N/A
    Coding: 0000012
    Coding: 0005128
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 233
    Mileage: 90098 km
    Time Indication: 0
    Date: 2018.09.19
    Time: 03:37:16
    Coding: 0000005
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 29
    Reset counter: 6
    Mileage: 97286 km
    Time Indication: 0
    Date: 2019.08.22
    Time: 22:08:25
    1 Fault Found:
    014 - Defective
    Coding: 0004148
    3 Faults Found:
    Revision: 00H15000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 50
    Reset counter: 24
    Mileage: 98422 km
    Time Indication: 0
    Date: 2019.11.24
    Time: 21:25:26
    Freeze Frame:
    Voltage: 14.13 V
    DU
    Temperature: 28.0°C
    RPM: 2163 /min
    Speed: 57.0 km/h
    Speed: 57.0 km/h
    Count: 0
    1 Fault Found:
    011 - Open Circuit
    Coding: 0004148
    1 Fault Found:
    Coding: 0000013
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 10
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 84776 km
    Time Indication: 0
    Date: 2017.09.03
    Time: 01:36:18
    Freeze Frame:
    Fault Priority: 10
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 84776 km
    Time Indication: 0
    Date: 2017.09.03
    Time: 01:36:18
    Coding: 0110211
    Please try this mate and give me feedback, please don't forget to Thank and Reputation.
    14 42 60 12 49 26 00 02 28 14 06 eb 92 22 00 41 39 00
    Buy every pirate China has to offer for cheap...and WIN!
    Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
