Results 1 to 2 of 2
Thread: ABS coding help
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Default ABS coding help
    Hello, Q3 ABs coding lost i trayed 0050308 / 0050311 , but nothink write incorect coding
    VIN: WAUZZZ8U8DR043685 License Plate:
    Address 03: ABS Brakes
    Control Module Part Number: 5N0 614 109 AF
    Component and/or Version: J104 C6 450M VD81 0120
    Software Coding: 0050308
    Work Shop Code: WSC 00049
    VCID: 6FED35377E68D7667D9-803A
    Advanced Identification
    Serial number: 00000006197229
    Identification: GNO-000
    Revision: --H07---
    Date: 19.09.12
    Test stand number: 0090
    Manufacturer number: 0959
    Flash Status
    Programming Attempts: 0
    Successful Attempts: 0
    Programming Status: 00000000
    Required Conditions: 00000000
    Flash Tool Code: 394758 024 12337
    Flash Date: 10.09.12
    Misc.
    Hardware number: 5N0 614 109 AF
    Lot Number: K03
    Type Lock: ----
    VCDS Info:
    Labels: None
    Maybe some one can help me ?
    Nov 2011
    Garage...
    Problem solved .!!!!
