Results 1 to 13 of 13
    Default Help to star a Renault Master iii 2.3 dci. ecm edc17c11 and uch BCM-N2
    The scantool says in the UCH unit The key isnt allocated to the vehicle. i did try immo off in bosh edc17c11 MPC but not work. Someone have experience in this type of car?
    Or some have tested solution?
    The bcm have nec v850 inside. i cant read. not have 8 leg eprom.
    i have a key too, but lonsdor want to pay for master iii option.
    Is the immo data only in UCH unit? can some extract pincode from ecu files?
    i did put here ori files. Please check.
    sorry bad english
    Dec 2018
    don't understand what to do with ecm
  3. The Following User Says Thank You to Catalizator For This Useful Post:
    arielcom (24th January, 2020)
    avital's Avatar
    vagimmocalculator.com
    simple solution use immo emulator for renault.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI - immobilizer solutions
    VAG IMMO CALCULATOR SOFTWARE
  5. The Following User Says Thank You to avital For This Useful Post:
  6. #4
    Dec 2016
    Quote Originally Posted by arielcom View Post
    sorry bad english
    simply program an new key ! no immo of , no read eeprom or flash .... use obd2 tool
  7. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
  8. #5
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by TERMINATOR1000 View Post
    Often mecanican with no starting car thingking better is immo OFF.
    But they have no idea how it could be hard and lose time.
  9. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    arielcom (24th January, 2020), Louislesinge (4th April, 2020)
  10. #6
    Ok. thanks to all. i will get another tool.
    recommended tool please?
  11. #7
    Agilechaveiros's Avatar
    Oct 2012
    São Paulo -SP -Brasil
    to enter key you have options like avdi and also by dump file, vvdiprog and tango
  12. #8
    Dec 2016
    RENOLINK , X100PAD 2 , RENAULT ECU TOOL ...
  13. #9
    i do a new key using lonsdor activation. Now the key its ok in uch. but the ecu is locked. i need a virgin file? or how to sync uch-ecu please. the car only crank 2 seconds and cut.
    I didnt have renault clip.
  14. #10
    Feb 2014
    london uk
    http://www.obdiitool.co.uk/wholesale...BoCkLwQAvD_BwE
    You need this cheap tool but will do the job.
    Sent from my SM-G955F using Tapatalk
  15. #11
    Dec 2016
    Quote Originally Posted by Mrcarkey View Post
    sOrry but NO !
    we need higher version
  16. #12
    Can i adapt it with dump file?
  17. #13
    Dec 2016
    No you can't
