11424012092200fe881002e790200042380000
Hello everyone, may I please have your assistance with the long coding for this ABS module.
Thank you in advance.
Tuesday,21,January,2020,14:24:24:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8P8AA104537 License Plate: STAGGA
Mileage: 84320km-52394mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 61 62 72
VIN: WAUZZZ8P8AA104537 Mileage: 84320km-52394miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH11--- Serial number: AUX7Z0IDFN301H
Coding: 0143000C24070060
Shop #: WSC 06314 000 00000
VCID: 4189F3051889CD429A-8014
6 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 84284 km
Time Indication: 0
Date: 2020.01.18
Time: 05:48:35
Freeze Frame:
RPM: 1647 /min
Load: 27.8 %
Speed: 28.0 km/h
Temperature: 98.0°C
Temperature: 47.0°C
Absolute Pres.: 880.0 mbar
Voltage: 13.589 V
008825 - Leak in Air Intake System
P2279 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 84287 km
Time Indication: 0
Date: 2020.01.18
Time: 05:53:15
Freeze Frame:
RPM: 773 /min
Load: 10.6 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 50.0°C
Absolute Pres.: 890.0 mbar
Voltage: 13.462 V
004506 - Fuel Pressure Sensor (G247)
P119A - 000 - Malfunction
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 84291 km
Time Indication: 0
Date: 2020.01.18
Time: 06:26:54
Freeze Frame:
RPM: 751 /min
Load: 8.2 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 58.0°C
Voltage: 13.462 V
000369 - Fuel Trim; Bank 1
P0171 - 000 - System Too Lean
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 84290 km
Time Indication: 0
Date: 2020.01.18
Time: 06:00:05
Freeze Frame:
RPM: 1057 /min
Load: 18.4 %
Speed: 7.0 km/h
Temperature: 98.0°C
Temperature: 48.0°C
Voltage: 13.589 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 84309 km
Time Indication: 0
Date: 2020.01.18
Time: 20:25:44
Freeze Frame:
RPM: 1628 /min
Load: 7.8 %
Speed: 60.0 km/h
Temperature: 90.0°C
Temperature: 24.0°C
Absolute Pres.: 900.0 mbar
Voltage: 14.097 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 98.0°C
Temperature: 50.0°C
Voltage: 11.938 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2667
Revision: 00043014 Serial number: 5ZV01401270359
Coding: 0000020
Shop #: WSC 00046 000 00000
VCID: 3A7B84E9755F9E9ADB-806E
5 Faults Found:
002113 - Transmission Fluid Pressure Sensor/Switch 1
P0841 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 10
Mileage: 81365 km
Time Indication: 0
Date: 2019.12.01
Time: 04:54:41
P0841 - 001 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 10
Mileage: 81365 km
Time Indication: 0
Date: 2019.12.01
Time: 04:54:41
006079 - Hydraulic Pump
P17BF - 000 - Play Protection - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 9
Mileage: 84185 km
Time Indication: 0
Date: 2020.01.18
Time: 16:10:23
006293 - Functional Restriction due to Pressure Drop
P1895 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 2
Mileage: 84263 km
Time Indication: 0
Date: 2020.01.18
Time: 01:11:03
006300 - Function Restriction due to Insufficient Pressure Build-Up
P189C - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 7
Mileage: 84277 km
Time Indication: 0
Date: 2020.01.18
Time: 02:53:05
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
VCID: 7AFB44E9F5DF5E9A9B-802E
4 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 84326 km
Time Indication: 0
Date: 2020.01.18
Time: 00:03:36
Freeze Frame:
Count: 3
Count: 14
Count: 28928
Count: 320
Count: 43776
Count: 0
Count: 1280
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 84326 km
Time Indication: 0
Date: 2020.01.18
Time: 00:03:36
Freeze Frame:
Count: 3
Count: 14
Count: 28928
Count: 195
Count: 43776
Count: 0
Count: 1280
Count: 0
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 191
Mileage: 84326 km
Time Indication: 0
Date: 2020.01.18
Time: 00:03:36
Freeze Frame:
Count: 7
Count: 14
Count: 28928
Count: 124
Count: 43776
Count: 0
Count: 1280
Count: 0
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 84326 km
Time Indication: 0
Date: 2020.01.18
Time: 00:03:36
Freeze Frame:
Count: 3
Count: 14
Count: 28928
Count: 295
Count: 43776
Count: 0
Count: 1280
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0140
Revision: 000448 Serial number: 8P0820043BK
Shop #: WSC 00000 000 00000
VCID: 76E350D901C73AFAFF-8022
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 84326 km
Time Indication: 0
Date: 2020.01.18
Time: 00:01:10
Freeze Frame:
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 06000A2FB0051AC0207040E02100895C437E2CAA116DD929E4 000E840041
VCID: 326BACC96D2F66DA13-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
1 Fault Found:
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 8
Reset counter: 228
Mileage: 82705 km
Time Indication: 0
Date: 2019.12.22
Time: 07:20:16
Freeze Frame:
Term 15 On
Voltage: 13.95 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB004JD6S
Coding: 30314238303830303132554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FADC53D16DD2B321C-801A
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000A1DC623X
Crash sensor for side airbag: front passenger side:
Serial number: 3582DRB40000A1DCB270
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB40000530B4839
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB400005282E53F
Crash sensor for front airbag: driver side:
Serial number: 35547RB4000052CBCB8+
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB4000052CC12CR
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0012112
VCID: 4683E01931A7EA7AAF-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 D HW: 8P0 920 932 D
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 224DI005021358
Coding: 0000928
Shop #: WSC 00000 011 2053004
VCID: 356197D55C4171E236-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0231
Revision: H17 Serial number: 1321J09C030055
Coding: ED817F06100202042103
VCID: 6BD571AD4A85F71210-803E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03005 Serial number: AUX7Z0IDFN301H
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004860
VCID: 4581E7150CA1E162A6-8010
2 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
008 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3169A3C5A8295DC26A-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 84285 km
Time Indication: 0
Date: 2020.01.18
Time: 05:50:04
Freeze Frame:
Battery Volts: 13.6 V
DU
Temperature: 49.0°C
Count: 3
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158954812451
VCID: 366390D941477AFA3F-8062
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004860
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 7AFB44E935DF5E9A9B-802E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3I5892001
Coding: 0310111
VCID: 428BFC091D8FD65A83-8016
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0231
Revision: -------- Serial number: 1321J09C030055
Coding: 0302085A
VCID: 68DF0EA19B73DC0A7D-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790836218
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000216
VCID: 4385F90D0295DF5288-8016
End-------------------------(Elapsed Time: 03:22)--------------------------
Buy every pirate China has to offer for cheap...and WIN!
Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
Tefocm (28th January, 2020)
Hello
I have one small problem i can't get long coding code
WAUZZZ8P99A055912
Audi A3 1k0907379AE MK60EC1
Hello
please help with skoda long coding
thank you
Typ podwozia: 1Z-SK35 (7N0)
Skan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z7B8028809
01-Silnik -- Stan: OK 0000
03-ABS Hamulce -- Stan: usterka 0010
04-Kąt skrętu -- Stan: OK 0000
08-Auto HVAC -- Stan: Awaria 0010
09-cent. Elekt. -- Stan: Awaria 0010
10-Wspomaganie parkowania/kierowania -- Stan: usterka 0010
15-Poduszki powietrzne -- Stan: usterka 0010
16-Kierownica -- Stan: usterka 0010
17-Przyrządy -- Stan: Awaria 0010
Bramka 19-CAN -- Status: Awaria 0010
25-Immobilizer -- Status: usterka 1010
42-drzwiowy, kierowca -- Stan: usterka 0010
44-Wspomaganie kierownicy -- Stan: usterka 0010
46 – konw. centralny -- Stan: OK 0000
52-drzwi elekt, przepust. -- Stan: Awaria 0010
56-Radio -- Status: Nie zarejestrowany 0011
Adres 01: Etykiety silnika: 03G-906-016-BKC.clb
Nr części SW: 03G 906 021 TB HW: 03G 906 021 AN
Składnik: R4 1,9l EDC 000SG 2047
Wersja: --H13--- Numer seryjny:
Kodowanie: 0000071
Numer sklepu: WSC 73430 790 00123
Numer VCID: 72EAE2546DAF20D41E-8026
Nie znaleziono kodu błędu.
Gotowość: 0 0 0 0 1
Adres 03: Hamulce ABS (J104) Etykiety:. 1K0-907-379-60EC1F.clb
Nr części SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Składnik: ESP MK60EC1 H31 0108
Wersja: 00H31001
Kodowanie: 000000000000000000000000000000000000000000
Numer VC: 75E0D948DCC137EC3B-8020
Znalezione 3 usterki:
01042 - Przełącznik Tiptronic (F189)
000 - -
Stopklatka:
Stan błędu: 01100000
Priorytet błędu: 2
Fault Frequency: 1
Reset counter: 124
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:20:13
Freeze Frame:
Count: 16391
Raw, Form. N/A: 054 000 000
Raw, Form. N/A: 054 096 000
Raw, Form. N/A: 054 000 195
Count: 46080
Raw, Form. N/A: 054 001 000
00768 - Fuel Level Sensor (G)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 124
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:19:13
Freeze Frame:
Count: 3
Raw, Form. N/A: 054 112 000
Raw, Form. N/A: 054 001 039
Count: 46336
01408 - Temperature Sensor (G18)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 124
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:19:13
Freeze Frame:
Count: 3
Raw, Form. N/A: 054 001 014
Count: 46336
Address 08: Auto HVAC (J301) Labels:. 3C8-907-336.clb
Part No SW: 3T0 820 047 R HW: 3T0 820 047 R
Component: AC Manuell H16 0401
Revision: 00007001
Coding: 0000000002
Shop #: WSC 73430 790 00123
ASAM Dataset: EV_ACManueBHBVW63X A01010
ROD: N/A
VCID: 3E720664A177B4B42A-806A
No ASAM data for: "EV_ACManueBHBVW63X" (VW36 *)
3 Faults Found:
13832530 - ROD - Unknown Error Code
- 00 [008]
Intermittent - Confirmed - Tested Since Memory Clear
13833043 - ROD - Unknown Error Code
- 00 [008]
13766916 - ROD - Unknown Error Code
- 00 [008]
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 085 H HW: 1K0 937 085 H
Component: BCM PQ35 B+ 104 0615
Revision: 00104 AE
Coding: 40000AB8A0050CB040100084110000A4430000AE524D81605C C440000040
VCID: 3466244C973B6EE4CC-8060
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 08121 26 0601
Coding: 00D7B7
10 Faults Found:
01800 - Door Warning Lamp; Rear Left (W37)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 164
Mileage: 255551 km
Time Indication: 0
Freeze Frame:
Term 15 On
Content: 68.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
00896 - Fuse for Wiper Motor (S128)
000 - - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 24
Reset counter: 164
Mileage: 362415 km
Time Indication: 0
Date: 2057.14.22
Time: 00:02:03
Freeze Frame:
Term 15 On
Content: 68.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
01312 - Transmission Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 164
Mileage: 362415 km
Time Indication: 0
Date: 2057.14.22
Time: 00:00:01
Freeze Frame:
Term 15 On
Content: 68.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
00976 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 53
Reset counter: 124
Mileage: 362415 km
Time Indication: 0
Date: 2057.14.22
Time: 00:00:10
Freeze Frame:
Term 15 On
Content: 68.5 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
02384 - Telephone Mount (R126)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 53
Reset counter: 124
Mileage: 362415 km
Time Indication: 0
Date: 2057.14.22
Time: 00:00:01
Freeze Frame:
Term 15 On
Content: 68.5 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
Freeze Frame:
Fault Priority: 1
Fault Frequency: 51
Reset counter: 124
Mileage: 362415 km
Time Indication: 0
Date: 2057.14.22
Time: 00:00:01
Freeze Frame:
Term 15 On
Content: 68.5 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
00144 - Supply Voltage for Acceleration Sensor Front Left/rear Right
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 8
Reset counter: 164
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:08:43
Freeze Frame:
Term 15 On
Content: 36.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 164
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:08:43
Freeze Frame:
Term 15 On
Content: 36.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
00432 - Front Right Inner Parking Aid Sensor (G333)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 164
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:08:44
Freeze Frame:
Term 15 On
Content: 29.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
00528 - Mass Air Flow Sensor Reference Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:08:48
Freeze Frame:
Term 15 On
Content: 25.0 mm
Mileage: 1350 km
Mileage: 1350 km
Term 50 Off
Mileage: 1360 km
Mileage: 1360 km
Address 10: Park/Steer Assist (J446) Labels:. 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32931034400105
Coding: 00000E
Shop #: WSC 13765 790 00123
ASAM Dataset: EV_EPHVA14SXkxx0000 001001
ROD: N/A
VCID: 336427509A3569DCD5-8066
No ASAM data for: "EV_EPHVA14SXkxx0000" (SK35 *)
2 Faults Found:
14024706 - ROD - Unknown Error Code
- 00 [008]
12801299 - ROD - Unknown Error Code
- 00 [008]
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC225VSU
Coding: 0020786
VCID: 3D7001686471AFAC33-8068
Subsystem 1 - Serial number: 633 SME 6
Subsystem 2 - Serial number: 6342MSME594471035
3 Faults Found:
01221 - Control Module Does Not Match Vehicle
010 - Open or Short to Plus - MIL ON
004 - No Signal/Communication - Intermittent - MIL ON
002 - Lower Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BH HW: 5K0 953 569 C
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101206100453
Coding: 1080040000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 73E4E750DAB529DC15-8026
2 Faults Found:
245252 - ROD - Unknown Error Code
- 00 [008]
267269 - ROD - Unknown Error Code
- 00 [008]
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 803 S HW: 1Z0 920 803 S
Component: KOMBI H05 0607
Serial number: 00000000000000
Coding: 110200
Shop #: WSC 73430 031 00064
ASAM Dataset: EV_Kombi_UDS_DVD_RM09 A04114
ROD: N/A
VCID: 4486748CCF9BDE647C-8010
No ASAM data for: "EV_Kombi_UDS_DVD_RM09" (VW36 *)
2 Faults Found:
9453842 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 255533 km
Date: 2087.14.11
Time: 00:00:13
13635841 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 164
Mileage: 362411 km
Date: 2087.14.11
Time: 00:08:39
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 031210F6000212
Coding: 352302
VCID: 306E285C632352C4A8-8064
4 Faults Found:
00381 - Optical Databus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 73
Reset counter: 164
Time Indication: 0
00464 - TV Tuner (R78)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 164
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 164
Time Indication: 0
01040 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 106
Reset counter: 255
Time Indication: 0
Cannot be reached
Cannot be reached
Component: EPS_ZFLS Kl. 68 3001
Revision: 00H17000
VCID: 31682D58A8295BCCA7-8064
2 Faults Found:
04315 - Unknown Error Code
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 11.9 V
Text: DFa6
Text: ˜GÚ—
Text: |a»˙˜GÚ—
Text:
Text: &T
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 164
Mileage: 362411 km
Time Indication: 0
Date: 2023.14.11
Time: 00:00:04
Freeze Frame:
Text:
Text: DFb
Text: ˜GÚ—
Text: |a»˙˜GÚ—
Text:
Text: &T
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Component: Tuer-SG 009 2119
Coding: 0000052
Numer VC: 479C638036ADF57C99-8012
Znaleziono 1 błąd:
01829 - Antena do monitorowania ciśnienia w oponach; Przód (R95)
006 — Zwarcie na plus — Przerywany
Hello everybody.
I need some help coding an abs module from an audi A3 8p.
I need to do longcoding.
1K0907379AD
Engine: 1.9 TDI BLS
BRAKES: FRONT 280MM REAR 253MM
VIN: WAUZZZ8P99A150339
Someone can help me?
