Results 1 to 3 of 3
    Feb 2019
    Default MMI 3G/3GP test platform, bench testing
    I have set up a bench testing loom for testing MMI out of the car but I have a problem.
    MMI 3G High
    Everything is working fine except software update. When I put SD card and go tu engineering menu there are only 3 positions:
    Sss - set to N
    MuTrnRef - set to Y
    MUconsistency - set to Y
    When I press Start Download system is freezing...
    Map update is working fine, emergency update working fine. Tried different softwares and SD cards.
    There is no gateway connected ad this moment - only MOST loop. Maybe that's the problem?
    Any help would be appreciated
    Sep 2016
    You need gateway for that module.
    Feb 2019
    Quote Originally Posted by congobg View Post
    Is diag line to gateway enough or both MOST and diag?
