Results 1 to 15 of 17
    Default chrysler pt cruiser immo
    2006 reg. Auto. Problem is battery was disconnected, now immo light stays on solid and will not turn over. I tried battery disconnect but still the same. Is there anyway I can disable immo on this car. I no skim module is fitted around ignition. Can anyone help please.
    Quote Originally Posted by radiosolutions View Post
    Anyone help please
    rafal's Avatar
    UK - PL
    if you will post more info............................
    need help
    now my goal is to buy xp-005
    who will help?
    Car is a 2006. 2.5 petrol cabrolet. Red immo light stops on and car will not crank
    avital's Avatar
    vagimmocalculator.com
    What color is the car?
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI - immobilizer solutions
    VAG IMMO CALCULATOR SOFTWARE
  6. The Following 2 Users Say Thank You to avital For This Useful Post:
    caliskan71 (7th February, 2020), ker0sin (23rd April, 2020)
    Black in colour
    szengen's Avatar
    Jan 2017
    have you installed any diagnostic tester?, send key photo
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
    type immo box? or engine unit?
  10. #9
    Quote Originally Posted by okura View Post
    Ecu and skim and tipm module pictures attached. I check if skim sees key correctly and it does. Immo light flashes slowing. Only faults in car are 2 in airbag and one in abs. Engine ecu has 4 plugs going into it.
  11. #10
    Fault codes in airbag and abs attached.
  12. #11
    Meat-Head's Avatar
    1) check all t’ fuses
    2) what radio
    3)UNPLUG HEATER CONTROLS- if easy enough
  13. #12
    Pictures of skim immo box attached
  14. #13
    Picture of engine ecu. 4 plugs in it
    Anyone no to a solution for this car
  15. #14
    Would it be possible to virginise the ecu using fvdi, then remove skreem module and reprogram ecu without skreem,
  16. #15
    Meat-Head's Avatar
    Is there no eeprom in ecu?
    or call dealer ask how much to recommend it back
