Can someone Remove P0234 VW Stage 2 2.0turbo
Results 1 to 4 of 4
    Mar 2017
    5
    Default Can someone Remove P0234 VW Stage 2 2.0turbo
    Can someone please Remove/Delete the:
    P0234 Turbo/SuperCharger Overboost
    When i went Stage 2 the car started doing this at WOT the boost spiks at 19 and hovers around 17 but about 3 out of 4 runs i go into limp m. and have to clear the CEL its annoying ive replaced the map mass airflow PCV delete installed a manual boost controller trying to fix this problem
    06 Jetta 2.0T
    Here is my tune
    HW: 0261S02080
    SW: 1037391667
    Mar 2011
    119
    yes i can.
    DK Veteran sdtsedat's Avatar
    Jan 2015
    Belgium
    202
    This is not the right solution to remove or cut this DTC.
    Check your tun, ori post ori and make log and upload that log so we can see what is the problem.
    ​Original Kess V2 + CMD + Autotuner + Winols + ECM geniune owner
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2
    Diesel + petrol
    Belgium
    Aug 2012
    48
    Quote Originally Posted by Brycbenn View Post
    06 Jetta 2.0T
    Here is my tune
    HW: 0261S02080
    SW: 1037391667
    why password :-D i dont understand
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
