In order to learn the new instrument cluster with VCDS you need the PIN from both instrument cluster. The easiest way to extract PIN code it's via OBD.
Another method will be to extract the PIN code from both ECUs (if you have the maxidot cluster ECU as well).
You can also make IMMO off and put the new instrument cluster with maxidot (to get rid of the IMMO OFF dtc you have to use the original maxidot ID48 Chip and put it in your own key)
The easiest way to program the new instrument cluster it's via OBD with specified software like Abrites/FVDI.
