What firmware revision are you using?
I dont know how do i find out
Press menu, config and system info.
Need the SW date.
Model DVB-XC BOX TDA
S/W VER 1.0 STC4 APR 10 2008
H/W 2.0t
Bookstrap v002
Website -------
this is what is there
Latest revision for the Red box is 21/04/08 the version you have was somewhat rushed after the April CC change.
Try a reflash with the latest Red firmware Digital Kaos - Downloads - eurovox max blue and red.21.04.08.fix
Another thing to check is your time settings are correct. Are you in the UK or Ireland as they differ in regards to EPG time settings?
i am in the uk flashed the box and changed the time to gmt still no epg any other thoughts
As its BST have you got it set to GMT +1? Strange that you are not picking up any EPG at all? What part of the UK and who is the provider, e.g. Telepest, etc?
I am in Scotland and with telrpest the time is set to GMT+0
As said in previous post you need to set it to correct time and GMT +1.
set time to GMT+1 is there something more to be done or should the epg come on when i press the fav key
No EPG at all, even when you press FAV, EPG or exit buttons? If so, unplug the box for a minute and then plug it back in, dont forget to check time setting again.
