In my case situation is very similar - car went to economy mode when I read pin code.
Maybe someone have flash for these?
I have problem with BSI, information about unit below:
All worked fine before changed odometer by FVDI. Now problem is like no power in car.bsi04ev k05-00 - 120510 - 96 640 591 80 02
v05.02 - 281201948D - NS06910863
BOOT 2097777-1 - HARD 281192496D
SOFTWARE SIGNATURE: 7B.6F
EEPROM should be fine, but flash could be bad. It looks like BSI is freeze in BOOT MODE.
Copy of flash from My Documents probably is damage, because application shows "checksum error".
83261584_174832357160477_2296856580420796416_n.jpg 83467649_567055807356290_6206797057814953984_n.jpg
Maybe someone have working flash or could repair checksum error: 7B.6F?
Thanks in advice!
eco mode is not the same as Boot mode, eco mode is easy to fix it, you dont need flash
sagie1zn (29th January, 2020)
Here are two flash of the same BSI, dont forget to thanks and rep
@koolstuff
From your side is very rude
https:/ /www.digital-kaos.co.uk/forums/showthread.php/800401
A topic that interests me
Have to tried to put your BSM into another car to wake it up then put it back into your car it should work fine.
Then with FVDI lift your wipers off the windscreen to help power drain, and connect a good constant power supply at least 4amp continuous.
Redo kms should fix issues.
My problem was solved:
Today I inserted my BSI to Citroen C4 and connect car to external battery charger, then connect interface and again try read code. Reading process proced sucesfully. Next BSI was connected to my car and all work fine.
Thank you all!
jomberykaso (30th January, 2020)
