    Jul 2013
    romania
    Default pin code need for edc16u34 ecu from vw golf 5 to add new key
    pin code need for edc16u34 ecu from vw golf 5 to add new key,please...i will atach eeprom files 95320 ecu is bosch edc16u34 0281013606
    alecsander114's Avatar
    Aug 2013
    Galati
    Quote Originally Posted by cutiutza View Post
    try 05954 or 06002
  3. The Following User Says Thank You to alecsander114 For This Useful Post:
    cutiutza (29th January, 2020)
    POLAND
    according to me 06002 is correct pin
  5. The Following User Says Thank You to voltec For This Useful Post:
  6. #4
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Pin not enought
  7. The Following User Says Thank You to drugowaz For This Useful Post:
    cutiutza (12th February, 2020)
  8. #5
    Apr 2016
    uk
    Depending on the year of the car pin code might not be enough.after 2007 you need to precode the transponder to be able to learn the key..
  9. The Following User Says Thank You to comizelu For This Useful Post:
  10. #6
    Jul 2013
    romania
    thanks..all ok
