I'm lost. The posted ISN is already in the CAS.
Hello I have a mini R56 I was forced to replace the DME. and now I have to replace ISN in CAS3 +. can someone help me replace the dump eeprom isn? thanks a lot.
551CDBAB1CCA74F170234E3A5117F862 INS
key info for decrypted. keys 1: 33 E3 35 98
crypto: low 6b 9f d9 b3 high: c6 1a
CFG / pass: c8 49 1e 4b
TMCF / psw C8 32 70 23
user 1: 04 62 11 54
user 1: 30 66 13 22
user 2: FF 21 13 0b
usser 3: FE 00 01 3rd
here is all the info for the decryption.
and change ISN of DME because I put a new DME.
I also attached the DUMP of the DME if necessary. these a MEV1722
<---- Coin of the Realm.
relating to ista it always shows me the same error code.
the isn code i wrote down is the right one in the DME dump?
tell my m8
do you start car with your changes
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
no it doesn't start. engine light stays on.
Yes of course. joint DUMP DME and that of the eeprom. I could not recover the old DME because it was HS nobody could extract the dump.
Tr m8
and post result
dump eeprom that I need to restore?
I try that and give you the result
try both dumps and still not and do not start.
what error in cas and dme
when I edit my DUMP MEV1722 in the part where I find the ISN code there is also a series of repetitive code starting with 63 this will not be there and I will be wrong code? because when I read ISN code with ACDP it gives me the first my editio there is a second
after rummaging around I noticed a possible error. a missing figure on the ISN code 551CDBAB1CCA74F170234E 3 A5117F862. the 3 between E and A was not entered. can someone check and modify?
where are not entered number 3
