Results 16 to 30 of 31
  1. #16
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by droidwayne65 View Post
    Well, they finally brought ELV and BCM2 this morning. Now what? I couldn't persuade the owner to just get a key from the dealer. He says he'll do that only if I try and fail. So now I'm faced with the ethical question of trying to do it or simply lying and say I failed.
    go ahead lion have faith in yourself, and no problem
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  2. The Following User Says Thank You to doctore For This Useful Post:
    droidwayne65 (14th February, 2020)
  3. #17
    droidwayne65's Avatar
    Aug 2015
    North America
    Well, I'm giving it a shot. Just read ELV and BCM2 and I'll continue tomorrow.
    <---- Coin of the Realm.
  4. #18
    super jumbe's Avatar
    Livingstone
    Look at this video this may help you good luck.....
    https://www.youtube.com/watch?v=dAzTehyRc9Y
  5. The Following User Says Thank You to super jumbe For This Useful Post:
  6. #19
    Aug 2015
    North America
    Making progress. I went by the car this evening, made the Dealer key with VVDI2, using BCM2 and ELV data. The Key Learning was a pain because the damn BCM refused to wake up and go into diagnostic mode. I bridged the two circuit 15 relays, unplugged and plugged the BCM, went to start it's dumping routine and once it was awake, I quickly switched back to Key Learning. Lo and behold, it learned the key and turned the car on with "SAFE" displayed in the cluster . Tomorrow I'll go back and use the ECU dump to actually start it. Although I'm sorely tempted to attempt to disable the immo in the ECU.
    Hmmmm... Continental ECU, so I guess logging can bus it is, LOL!
  7. #20
    Apr 2016
    uk
    Well done!
    Ecu dump is useless!
    Look at the third step on vvdi2.
    You need to connect to internal can on the car!
  8. The Following User Says Thank You to comizelu For This Useful Post:
    droidwayne65 (18th February, 2020)
  9. #21
    DK Veteran ASCM's Avatar
    Oct 2018
    Did you maked that?
    Sent from my SM-J415F using Tapatalk
  10. #22
    Aug 2015
    North America
    Quote Originally Posted by ASCM View Post
    Did you maked that?
    In a holding pattern right now. The car doesn't have a CVT, I can't read Audi SIMOS 18, which VVDI2 says is required in that case, so the ECU was sent out to a guy who can read it. I'll resume when the ecu and file are returned.
  11. #23
    Aug 2015
    North America
    Well done!
    I tried connecting to the can bus at the ABS then to each bus at the BCM. Absolutely no joy. And still this guy refuses to tow the car to the dealer, so we sent the ECU out.
  12. #24
    Apr 2016
    uk
    He has to order the key if he has paperwork for the car.
    You can learn it no problem.
  13. #25
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Stolen car maybe
  14. #26
    Aug 2015
    North America
    Quote Originally Posted by drugowaz View Post
    Stolen car maybe
    LOL! My bud says the guy is legit but I confess the thought did cross my mind after this last episode.
  15. #27
    Feb 2015
    Istanbul/Turkey
    Hi everyone,
    I worked on a AUDI S6 2013 yesterday. I couldnt program by obd. But finally i have connected the AURO IM600 after a few try, auro says take out BCM 2 energie socket and put back. After i do it, car sleeped. Before these when i push to start button, car was says key couldnt found on the dashboard.
    What can i do to turn back normal ?
    Erem GUNES
    Istanbul/Turkey
    Working with Immobiliser systems..
  16. #28
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by eremgunes View Post
    Hi everyone,
    Car had 1 working key and you tried to add extra one, is it right? The message you got is strange because when you have working key, you should never need to disconnect BCM power during procedure.
  17. The Following 3 Users Say Thank You to p1et For This Useful Post:
    ASCM (31st May, 2020), droidwayne65 (29th February, 2020), super jumbe (31st May, 2020)
  18. #29
    Oct 2018
    Hi everyone,
    Did u solved?
  19. The Following User Says Thank You to ASCM For This Useful Post:
    p1et (31st May, 2020)
  20. #30
    g5n14's Avatar
    Aug 2018
    Hey man! I faced kind of the same car. What was the end of the story?
