Page 1 of 5 12345 LastLast
Results 1 to 15 of 66
    May 2017
    Default Land Rover Defender TD5 ECU repair
    Hi everybody!
    In a Land Rover Defender TD5 with MSB101171 ECU after a short circuit in the fuse box some of the tracks on the black connector were destroyed.I have not a schematic for this ecu and no pinout diagram to repair...
    Does anyone have the pinout for black connector?
    Meat-Head's Avatar
    Its fcuked, you need a new one.
    got verdis gris init, get used from junkyard and swap eeprom
    May 2017
    i have checked everything is ok only some tracks from power connector have destroyed.I am trying to repair it and if not i will be looking for another one though it is hard to find
    Meat-Head's Avatar
    Must be thosands on eBay all nicked ones
    Mar 2011
    Romania
    It is easy to do immo off , or you can swap the eeprom , replace the unit !
    May 2017
    i'm trying to find MSB101171 i dont know if other MSB.... is compatible
    May 2017
    did you know for 1999 defender 2.5 td5 compatible ecus?
    May 2017
    I have find MSB101191.Did anyone knows if is compatible with MSB101171?
    Aug 2008
    most msb modules will work unless it came off an automatic then the answer is no
    replace the flash and eeprom if you want it to be exact
    ROVER MSB1011171 1999 defender 44pin A0016 LDMAN41 A0015 0541
    ROVER MSB101170 A0016 LTMAN41
    ROVER MSB000080 3190 A0016 LDMAN41
    ROVER MSB101181 3438 1999 discovery 44pin A0016 LTMAN41
    ROVER MSB101183 1999 discovery 44pin A0016 LTMAN41
    ROVER MSB101184 A0016 LTMAN41
    ROVER MSB101191 A0016 LTMAN41
    ROVER MSB101193 A0016 LTMAN41
    ROVER MSB101330 1999 discovery A0016 LTMAN41
    ROVER MSB101340 AUTO discovery LT AUTO4145
  10. The Following User Says Thank You to tango For This Useful Post:
    georgedigital (31st January, 2020)
  11. #10
    May 2017
    Finally find MSB101191 swap the eeprom and car starts ok...After the car warm up trying to start and dont start...Take off same ecu from other car swap eeprom and same...What happened?I've started to go crazy...
  12. #11
    Aug 2008
    sounds like immo problem
    you would have best to change flash and eprom from broken ecu to new ecu
    the plcc44's are otp so you have to remove and replace
  13. The Following User Says Thank You to tango For This Useful Post:
    georgedigital (14th February, 2020)
  14. #12
    May 2017
    Thanks tango i will do...I don't know if is easy to do immo off.I have try it with no success
  15. #13
    Aug 2008
    immo off is easy post eeprom dump
    but you need to replace the plcc44 with the one from broken ecu has it is different software
    and then put the broken ecu's eeprom on new ecu and test
    do you have diagnostics for td5 ie rovacom or nanocom?
  16. #14
    May 2017
    Here the dump of eeprom.I haven't a diagnostic tool for land rover.I have autocom
  17. #15
    Aug 2008
    cut pin 34 on black plug
  18. The Following 2 Users Say Thank You to tango For This Useful Post:
    georgedigital (15th February, 2020), klonone (18th January, 2023)
