I don't think this is a well read file!
Hi collegue,
I have bosch srs module from old Ford Puma my2000 0285001348
In airbag i have stored error B1342
YS6T14B056AC - 0285001348 (68HC912B(E)32)
Carprog read from obd but not delete error.
I add ori file whit B1342 error.
Many tnks
To Push Buttons,Thanks and Reputation is always best way to thanks!
Fabiuz (30th January, 2020)
i have press tnk's and rep try and report
I made a mistake!
Your file is too short.
Try to read again
i have read whit carprog obd.
you need full read mcu on bench?
Well yes!
If i try to do it!
You can wait someone to help like that!
Your file is 640 bytes -270
The MC68HC912BE32 EEprom is 768 bytes -2F0
Whit upa i have bad VDD pin9 connection.
Have you pinout onboard for this srs module?
You can read the chip with carprog! Here is link for manuals
http://www.codecard.eu/files/Manuals...r%20manual.pdf
but i don't found my package whit 44 pin. All QFP80
You wrote on first post that the processor is MC68HC912BE32,but that is not true.
This is CR16 SRS Unit.
Try to put this file wit carprog obd!
agstur is correct, crash is stored in CR16MFR544 MCU.
Tnk'all i have found mcu info in tachosoft web site.
i have try to write other file cleaned and readed by other srs unit from fiesta, but have error verify and error stored always.
I have resolved whit buy other srs unit from ford fiesta, whit last 2 bosch number different, but ever whit 2 srs airbag unit installed.
