Results 1 to 7 of 7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default Renault edc16c36 failed on obd
    Hi, i have renault trafic. After writing mod file with kess (Original) , car started to drop rail faults, engine is working roughly, rpm shaking. Coding was readed before, writed after few times, no success.
    We written original file ,but same situation. I found bdm reading in this forum, written it over OBD but same situation, written same bdm reading on bdm with Ktag (original) , also same. Can someone see if eeprom corrupted?
    1037388183
    i attach ktag reading
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Ignasvw View Post
    ... Coding was readed before, writed after few times, no success.
    which year it is...?
    you read/wrote by can bus...?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by figani View Post
    2008/Kline
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    This is 2.5dCi. You must change type of FUEL PUMP in engine ecu coding. From TYPE 1 to TYPE2 (or from 2 to 1, i don't remember).
    Make it with Renault Clip or LAUNCH.
    This is all you need.
  5. The Following 3 Users Say Thank You to Inquizit0r For This Useful Post:
    Ignasvw (3rd February, 2020), NASTASE (3rd February, 2020), stanislav georgiev (3rd February, 2020)
    Babos's Avatar
    Mar 2012
    Friend try adopted rail presure and regulator sensors!!!
  7. The Following User Says Thank You to Babos For This Useful Post:
  8. #6
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Yes you must do all adaptation you have in Renault Clip after that all will be ok . I had similiar situation. Just reading and writing will erase parameters.
    Sent from my TELEFON
    Here to HELP!
  9. The Following 3 Users Say Thank You to immokill For This Useful Post:
    brmservice (3rd February, 2020), Ignasvw (3rd February, 2020), stanislav georgiev (3rd February, 2020)
  10. #7
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    this ecu always to read and flash with CAN not Kline
    and like others writted make all adaptation with Can Clip or Launch and all will be ok no worry
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  11. The Following User Says Thank You to AVDigitale For This Useful Post:
