i have fault 93B3 airbag passanger stage 2 inside ECU BMW E91. Airbag is good, wires and connector too. Is it possible that the ECU is bad? If I buy a new ECU, can I connect it without coding, or do I have to code? The car started many times with the wrong battery. ECU number is 9119058.
IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
raceshadow (4th February, 2020)
Or replace ic for this output, if you short line ecu recognize short?
I finally had time to work with BMW. I solved it by exchanging the ecu. I copied the eeprom from the old ECU to the new one. The error is gone, but an error is now stored inside the unit. He writes a problem with the software version. But the airbag does not light up on the instrument panel, so it's probably ok :-)
