did you try the first version that you worked with this cable?
Maybe loader is corrupt?
Hi guys
I am trying for more than two days to install and have it working, a bloody VCDS high quality clone HEX-V2. It worked in the past with 18.9.1 and loader 7.2. Done everything in the world to have it working on three PC's but cannot make it work again. Bootloader is enabled. The loader starts and closes after few seconds. No antivirus active.
Any help will be welcome!
Yes. Did all. Not sure if loader is corrupt.
If its high quality hex clone,then it should work without loader.
Mine for example works with original vcds soft without any crack.
i have other cables that work till 17.8.After that,not possible.
Do you have a photo with the interface? Your works without loader?
http://blog.vxdas.com/vcds-software-...install-guide/
thats the one i use no problem,remember to update cable with firmware.
Thanks for the suggestion but not all of us bought the cable from vxdas so we cannot get activation from them
The original plan works with kolimer,i try and works without chineze loader,first check with hwtype to see if cip is enabled and then use hwrite to rerwrite!
As I said, bootloader enabled, written firmware, loader closes after few seconds and vcds doesn't start
