Results 1 to 15 of 23
Hybrid View
    Mar 2018
    Exclamation FGTECH 0475 Won't Boot
    Hi guys
    I've been trying to install FGTech 0475 on windows 7 32bit.
    Everything seems to install ok but it won't launch .
    When I try and launch it I get a message saying "windows vista or above detected , making second patch" then the fgtech device makes a couple of clicks and that's it.
    Does anyone know a fix?
    Thanks for any help given
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    try to start as administrator...
  3. The Following User Says Thank You to figani For This Useful Post:
    Inked (7th February, 2020)
    Mar 2018
    Quote Originally Posted by figani View Post
    Thanks for the reply
    I've tried running it in xp sp3 compatibility mode and running it as admin but it still won't launch.
    I've also tried installing it directly on C: drive and I have no antivirus or firewalls .
    Aug 2008
    Quote Originally Posted by Inked View Post
    you dont need compatibility mode just run as administrator
    win7 32bit works ok
    blackpirate's Avatar
    Jun 2009
    try this !
    yes, it change date, but will be reset automatic after exist software
    hxxps://mega.nz/#!mkt20BCZ!kfWQp12Sq-8XJPcbg-vx92Md5_W_RAerMfD5PbmdOyU
    replace xx to tt
    If freedom is outlawed, only outlaws will have freedom!!!!
  7. The Following User Says Thank You to blackpirate For This Useful Post:
  8. #6
    Mar 2018
    Quote Originally Posted by blackpirate View Post
    try this !
    replace xx to tt
    Thanks I'll give it a go
    What is it?
    From the name it looks like a firmware flasher.
  9. #7
    Mar 2018
    I went into windows event viewer and it shows that eobd2 is crashing.
  10. #8
    Mar 2018
    try this !
    replace xx to tt
    I downloaded it but it's just a flasher
  11. #9
    Feb 2018
    to start the 0475 software first you need to connect it to the car, or that adapter to the power, then the software will start, after that it will start every time, whether you are connected to the car or not
  12. The Following User Says Thank You to zoki21 For This Useful Post:
    Inked (9th February, 2020)
  13. #10
    Mar 2018
    Quote Originally Posted by zoki21 View Post
    I haven't tried connecting it to a car using obd yet , but I have been trying while it plugged in using the power supply.
  14. #11
    Feb 2018
    well you have installed and you should hear that click since the windows vista appears, just do as I told you, do not insert anything further into the program 0475
  15. The Following User Says Thank You to zoki21 For This Useful Post:
  16. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    You don't need to connect it to car...
    Check your driver, you didn't install it correctly,
    I had the same problem, and in some times I must
    run the program 2-3 times to start....
  17. The Following User Says Thank You to Panathaole For This Useful Post:
  18. #13
    Mar 2018
    Quote Originally Posted by Panathaole View Post
    How do you install the driver?
    I go into device manager and direct it to the driver folder that is in the fgtech installation folder.
    Edit:
    Is there a more up to date driver for windows 7 32bit amd processor?
  19. #14
    Feb 2018
    if that doesn't help you then you have bad hardware that is defective, Chinese bad copy
  20. #15
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Uninstall and remove the driver, and install again...
    Try to another pc or laptop...
  21. The Following User Says Thank You to Panathaole For This Useful Post:
