can i help you with immo off but i believe you will need to correct checksum
matarelec (7th February, 2020)
Thank you mate for your support,I have already tried that,it is IUD immo off but it does not work,the cars does not start and I can see by live data that ecu is blocked,I hope some other mates may help with a trusted immo off file or a virgin one.
matarelec (8th February, 2020)
mate,when you ask me to calculate the CRC-16 out of my user name you should say first in which type the output should be ...HEX,DEC,OCT BIN...I would leave that for somebody else who may have a lot of free time so may may try all the possibilities.
the CRC-16 of matarelec is 0xA386 and it does not work,let other members correct me if I am wrong.
why don't you virginize the bsi? , you use the same pincode with diagbox or pp2000 to co-appear everything again.
forget it..
Hi mate,
I have tested your file but I am sorry it did not work,I had to use a good ecu dump ,virgin bsi and program a new transponder.
Thanks anyway.
My friend, I have faced this type before and researched a lot, and I did not come up with a solution. I think there is no solution but to re-encode
