Results 1 to 5 of 5
    Feb 2012
    Default BMW e91 Remote control
    I have a car with problem remote control. Car not lock and unlock with remote key . The car had the battery disconnected and then remote pilot stopped working. Engine start ok and no faults in module. In CAS module a both key are Status : key in ignition is remote control. The keys are in position 0 and 1 and everything looks fine. I check fuses and i everything is OK. Central locking working only from interior lock button from dash. In driver door in lock not work. Before changing battery in car everything worked well. Please help how to program this remote pilots ?
    thanks for advance
    Mar 2018
    UK
    The problem is on the car not with remotes
    Feb 2012
    Ok thank you . I check aerial diversity from back car.
    regards
    Feb 2018
    Glasgow area
    Diversity antenna or wiring between tailgate and body.
    Jan 2019
    check with diagnosis if all doors end tailgate are close on GM BASIS,E90 E91 E92 not heave syncronisation procedure for remote control they use same binary code for starting end open/close
