Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    srt8's Avatar
    Nov 2017
    ok, tell me on this picture
  2. #17
    May 2017
    absolutely unmistakable ... connector to body...
  3. #18
    srt8's Avatar
    Nov 2017
    [QUOTE=Lambda1;3800613]absolutely unmistakable ... connector to body...[/QUOTE
    Hello guys. I finally sorted out the issue with the programmer and got also 2 different flashes and reprogrammed both master and slave. I installed correctly. Installed on the car, the check engine is on, the scanner has no communication. I had tried with kess and still nothing. It sees the car but gives this error. Posting the photo.
  4. #19
    srt8's Avatar
    Nov 2017
    I disconnected the dme and the check engine disappears. Installed a different dme and I can communicate with it.
  5. #20
    May 2017
    Did you write mine files via programmer, without anything touched?
    Which eproms did you use? Tell me hole name of em.
    Test to reprogramm via WinKfp
  6. #21
    srt8's Avatar
    Nov 2017
    i wrote the flash you sent me, both, the slave and master. nothing was changed. via programmer. no obd2 communication, no kess communication, i think. the kess sees the vin and model, the rest no. the check engine shows up. strange
