Results 1 to 15 of 17
    nairobi kenya
    Default benz me2.0 vin alignment
    hi all
    is it possible to change vin in this dump.original ecu burnt i want to use secondhand unit
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by automatemad View Post
    hi all
    Are you sure its there mate .......?If ..then what is it ...?
    Croatia
    I don't see the VIN inside, so the answer would be no, it is not possible to change the VIN in this dump. What car it is? Year? maybe You should post from some other dump..
    Cheers
    Thanks to all of You, guys
    Last edited by Dajan2009; 8th January, 2010 at 12:19 PM. Reason: solution available
    VIN is in line 20:CDCFCDCFCDCFCDB9C6CECCCCCFCE
    nairobi kenya
    Default decode
    Quote Originally Posted by ovidiu1967 View Post
    is possible decode to the real vin
    0 - CF
    1 - CE
    2 - CD
    3 - CC
    4 - CB
    5 - CA
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    Quote Originally Posted by Wynn's View Post
    0 - CF
    1 - CE
    2 - CD
    3 - CC
    4 - CB
    5 - CA
    the rest of the conversion table is available?
    I did try simple hex to dec but have not sense the numbers
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    hi all
    VIN in your file is 2020202F913301 and the car is manifactured for Japan
    6 - C9
    7 - C8
    8 - C7
    9 - C6
    Moderator
    PremierD's Avatar
    Jun 2009
    hi all
    Yes ..will now be the Answer mate .....Thanks to the above posters ....
    nairobi kenya
    Default original vin
    Quote Originally Posted by milanoffracing View Post
    this the original vin i needed in the dump WDB2020202f906439
    where is the WDB written in the dump
    also how does b9 convert to f
    regards
    Jakarta, Indonesia
    6 - C9
    7 - C8
    8 - C7
    9 - C6
    can you explain all the code contained in a hex dump?
    and is there a hex convert to word A-Z?
    regard
  13. #13
    you can put ff or cf and write correct VIN with stardiagnose. also is not enough to change just VIN , you need too to renew ecu and also for recalibrate with star you need SCN coding from old ecu.
  14. #14
    nairobi kenya
    Default old ecu burnt
    am unable to read from old ecu .can dumps from eis help ?
  15. #15
    Moderator
    PremierD's Avatar
    Jun 2009
    regards
    Eh!... B9 - F ...B8...- E .... HAve you Sussed ..it mate
    Took me Five minuites ...
