Here's an updated satellites.xml file for anyone that's looking for it.
13/09/08
Njoy!
No, it's the scanning settings for the 'Automatic Transponder Scan' menu.
If u don`t mind, I will update this post..
there is an online satellite xml generator for Dreambox, where you can customize and download your own satellites.xml file,
with the exact amount of satellites you need, get split different band transponders (C, Ku band...), HD or SD channels....
it`s constantly updated....
"Currently in database: 155 positions / 5943 transponders
Last update: 12,695 MHz @ Arabsat 2B 30.5E / 07.10.2008 @ 09:09 [GMT]"
satellites.xml generator
Hi, thanks for this useful post.
i have a question: with my DM500s, I can lock, scan these 3 satellites (hotbird, astra1 and astra2) and watch their channels without problem. only problem: arabsat 30.5: I can't get any lock and scan. Could it be that I have to update this file: satellites.xml?
The 28.2E satellite has a very strong signal in fact on my dish I get around 96% but than I also have a 1m dish.
You should get all channels with good signal quality with a 60cm dish, the signal is THAT strong.
if its motorised set up your arc could be out this would account for you only getting some transponders
If you tremble with indignation at every injustice then you are a comrade of mine
ok where does it go ??????
hi and tanks for the satellites.rar
loveme4212 (11th February, 2014)
